Question about Westclox 70034AX in-Out Temp-Digital Lcd Clock - Blue
Westclox 70034 how to set time
How do you set time and am or pm
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
Jan 13, 2014 | Westclox 47550 Quartz Loud Bell Analog...
How do i set year on westclox 70034 alarm clock?
You need to make certain that you have set the year right, otherwise it will show the correct day for say 2011, rather than 2013.
Jul 14, 2013 | Westclox LCD Dual Alarm Clock with...
I have 3 westclox clocks I have lost the instructions to set them. atomic clock Westclox 70026 cannot change the zone nor can I set the time to alarm
Manual on the link below.
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Oct 13, 2011 | Audio Players & Recorders
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
How do i set up my westclox 70034 outdoor thermometer to read on my clock unit.
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 16, 2010 | Vacuums
How do i set the thermo sensor 433mhz to my westclox 70034 model
Oct 11, 2010 | Vacuums
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
Westclox 70034AX in-Out Temp-Digital Lcd Clock - Blue Logo
93 people viewed this question
Top Westclox Audio Players & Recorders Experts
Joseph Hoffmann
ray gallant
Tom Chichester
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
