Question about Tomtom ONE 3rd Edition GPS
Tomtom one 4n01.002 - Tomtom ONE 3rd Edition GPS
How do i update my Tomtom 3RD Edition (1GB) GPS Systems for free i would appreciate it if you have an answer thanks.
Hi, I was having trouble too and have found the manual for the 3rd edition online
http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-GB.pdf
I'm following these instructions:
Installing TomTom HOME
Install TomTom HOME on your computer in the following way.
  • Connect your computer to the Internet and then connect your TomTom ONE to your computer using the USB cable.
  • A pop-up window appears. Select Run TomTom HOME. Click OK and follow the on-screen instructions.
  • If the pop-up window does not appear, browse to the TomTom device on your computer and run the file named Install TomTom HOME.
  • TomTom HOME is also available for download from the TomTom website.
  • For more information visit www.tomtom.com/home
  • Once installed, TomTom HOME will start automatically whenever you connectyour TomTom to your computer.
Hope this helps, Lynsey
Jan 06, 2011 | Tomtom ONE 3rd Edition GPS
TomTom 930 GO will not connect to TomTom Home
Try to use another computer or another usb port for it. You could also try different usb cable that fit´s into tomtom´s connector.
Jul 29, 2009 | Tomtom GO 720 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 920 bluetooth disabled
repair both ...start fresh from start.....do a hard restart on the TomTom...this is located on the last menu of your tomtom...Factory reset...it will erase recent destinations and favorites....but it usually clears the tomtom....Now try to repair both the phone and the tomtom
May 10, 2009 | Tomtom GO 920 GPS Receiver
Tomtom one
Yeep!
Connect yout tomtom to your pc/laptop, install the program that came with your tomtom, start the program and update your tomtom, it will install all the updates automaticly.
If you dont have the program/cd that came with your tomtom you can download it from here: http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_alp.php
Good luck
Nic
Mar 01, 2009 | Tomtom GO 300 GPS Receiver
My tomtom receiver is frozen on the start screen.
Connect your TomTom to the USB cable then turn on your TomTom in that order. Go to "My Computer" and open the drive that is your TomTom. Copy and paste your map folder to the desktop. Delete everything on your TomTom (don't format). After deleting everything on your TomTom. Open TomTom Home. TomTom Home will tell you, you need an application for your TomTom. Let TomTom Home load the application. You will probably have to do this at least 2 times to get the latest application for your device. After TomTom Home has loaded the latest application for your device closer TomTom Home and copy and paste your map back onto your TomTom. You should be ready to go after doing this. Make sure you do not skip a step when doing this.
Dec 27, 2008 | Tomtom ONE 130 GPS Receiver
ERROR: 573/#https://home.tomtom.com/shop/onetimeDeviceUpdates: Error from server: You have an invalid version of the TomTom application installed on your TomTom device. To use HOME you need to install the...
Go to My Computer, then the TomTom drive and click explore. Move your Map folder to the desktop. Then, delete everything on the tomtom drive. Unplug it, plug it back in, and start up Tomtom HOME and install all updates, keep unplugging, plugging back in, and installing updates until there aren't any more updates. Then move your map folder back to where it was on your TomTom drive.
Please rate, Thank you!
Dec 27, 2008 | Tomtom ONE 3rd Edition GPS
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
Tomtom One 130 shows pic of Tomtom, flashing x, pie chart icon on left after using Tomtom Home.
TomTom Home must have corrupted the TomTom's operating system. That is what that symbol means. Contact TomTom support and tell them what model you have and they will walk you through getting the correct version installed.
Oct 14, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
21 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
