Power button broken and laptop won't come up - Computers & Internet
    Champion:
  • 220 Answers
Replace the power bottom and retry
Posted on Mar 03, 2014
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
My lenovo S10-3t laptop won't start up. It has a black screen and the power button won't turn it on. It has a working charger that's plugged in. I already tried the unplug the battery and
For this kind of issue, please follow up the following steps to check:
1.confirm your Lenovo IdeaPad S10 ac adapter and battery connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includes two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
Dec 31, 2012 | Lenovo IdeaPad S10-3t 0651 Notebook
Hp laptop won't power on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 11, 2012 | HEWLETT-PACKARD G72250US Laptop
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
COMPAQ V2030US POWER ON WON'T START
if there are no Power light,you battery might be broken or your power button is broken,i suggest you to charge your battery or take it to notebook center (if charging still failed,it might be the button)
Aug 27, 2012 | HP Compaq Presario V2000 Notebook
Dell Inspiron 1501 Power Button won't turn on ....
I would remove the hinge / power button cover again and make sure the little pip that presses the button down it not broken, also check the little circuit board with the switch on to make sure it's not disconnected.
Try switching on with the cover removed.
Feb 02, 2012 | Dell Inspiron 1501 Laptop
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
V-star 650 won't start and the headlight won't come on. Battery was replaced, new gas put in. now what?
Replace your right switch assembly on the handle bar. Your starter button is dirty or broken and the only way to replace it is to replace the assembly. Your starter button is a two position switch that both turns off the headlight to direct more power to the starter and activates your starter solenoid. Either the right switch assembly has become unplugged from the harness inside the head light bucket or a broken power wire is causing the system to not work. But most likely a dirty or broken starter button is the cause of your problems.
Jul 07, 2011 | Yamaha V Star Classic Motorcycles
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
