Question about Seagate Computers & Internet
Seagate 32000542as where can i buy a replacement motherboard
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Seagate Master
  • 2,226 Answers
Go on ebay
Posted on Mar 31, 2014
New built pc biostar ta75m+ motherboard. System shuts down when I try to load windows.
Hello the homepage is here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=550#dl
I think the harddrive has a lot of bad sectors, and needs to be replaced.
It should not take 4 hours, to format the drive.
It normaly take 15 to 20 minutes, depending of the size of the drive.
Any sata drive will go for this mainboard.
Try not to buy seagate, western digital is better.
Check also the bios, for proper boot settings.
Good luck
Dec 15, 2012 | Biostar TA75M DDR3 2000 USB3 SATA3 AMD FM1...
Where can i purchase a replacement board for my seagate barracuda 7200.12? the usb slot has snapped off the board.
This is an internal hard rive and therefore does not have a USB slot. I assume you are referring to the SATA connector.
The control board is not an item that can be bought separately. You may be able to buy a used drive on ebay.
Try and find someone who can solder the connector back on for you.
Feb 22, 2011 | Seagate Computers & Internet
I am trying to buy a replacement hard drive for my acer aspire 3500... what type of hard drive am i looking for ? is it the hdd ide 60 gb... can i get bigger gbs..... also can i use an stat converter on...
You would have to buy a IDE/ATA 2.5" Hard Drive at 4200 rpm.
You can buy a 80GB one here.
The model number is Seagate ST9808210A
Its about $56 dollars.
You can not use a sata converter on the motherboard.
Dec 30, 2010 | Acer Aspire One PC Notebook
I have an old 40gb seagate (st340810A), i NEED TO KNOW WHAT CABLE TO BUY TO RECOVER THE DATA...
Just buy an "80-pin Parallel ATA" cable.
Hopefully, your motherboard has a socket to match the connector on the cable.
Oct 16, 2010 | Computers & Internet
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Planning to buy a hard disk
look on the board... if it has sata connectors .... use them as they seem to have a better data rate. i'm uncertain if you can still buy new 80 gb drives now... but your sources might be different then mine.
Mar 21, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Will the ms9327e + (usb) support a SATA drive?
well it depends on what board you have.
your best bet is to look on the motherboard.
the SATA connection looks almost identical to the connection on the harddrive, so you can use that for reference.
on the harddrive you will see 2 plugs. the smaller one plugs into the motherboard and the larger one is power.
for power, power adaptors are made to convert the standard 4 pin connector to a SATA one.
Feb 24, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Malfunction
You can try to take it out from the enclosure and plug the hard drive directly to your motherboard for you to retrieve the date. Or just buy a different drive enclosure.
Jan 21, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
