Bosch classixx 1200 express
Lights on spin cycle flashing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Check you filter and if not blocked check your pump
Posted on Feb 11, 2014
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Posted on Dec 22, 2008
rickead1
  • 1998 Answers
SOURCE: BOSCH 1200 EXPRESS CLASSIXX ALL RINSE SPEED
bunged up theres a new word does that mean that you took off the pump and cleaned out the hoses as well as the pump yet the lights are still flashing on your unit please message me back with your answer and any further questions you may have thanks again Rick
p.s this also would mean you have cleaned the drain hose line that goes from the pump to the outside of the machine and tested the line to assure that water is flowing out of the drain line in a steady stream of water I await your reply Rick
Posted on Dec 19, 2010
  • 196 Answers
SOURCE: bosch classixx 1200 express spin light
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Posted on Feb 28, 2011
SOURCE: bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Posted on Sep 25, 2012
  • 414 Answers
SOURCE: F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Posted on Mar 22, 2013
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Dec 05, 2011 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
