Question about Innovative Technology The Ultimate Film And Negative Scanner itns-500
Windows 8.1 My software disc ran successfully on my old computer (Windows XP), however my new computer has Windows 8.1 AND Microsoft states its not compatible. What can I do to download a update for my computer. Is one available!
Computer does not recognise Scanner -- why not?
How old is the scanner? did you read for what Windows version it was made in the first place?
If it is for an older OS then Windows7 and you are using Windows 7 or higher, you ran out of luck.
Always first install the software that came with the device. The driver needed for the device is supposed to be on the install disk.
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Veho VFS-008 Smartfix Film Scanner USB...
Where to find drivers for Tanberg SLR6
So most of the time the drivers that came with your tape drive, could be used with the operating systems of that time. Till Windows XP, you could install drivers yourself, even old and outdated drivers most of the time worked. In the newer OS'n you ran out of luck.
Jul 13, 2014 | Tandberg Data SLR 6 (6242-EVAL) SLR Tape...
I recently had to give up on my old computer with Windows XP so now I have the dreaded Windows 8. Can you tell me how to transfer my Forget me not calendar to my new computer? I have tried "send to" a...
Windows 8 doesn't run Outlook Express. If you are having problems with an old Windows XP program, you are out of luck. You will need to buy a newer version of the program if it is available. Don't worry about hating Win 8, you aren't alone. Everyone hates it, even Microsoft.
Aug 19, 2013 | Broderbund American Greeting CreataCard...
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
I use MS Money 2001. I bought a new PC and is changing from MS Windows XP Pro to Windows 7 Pro. I would like my ms money 2001 to continue working on new PC but I can't find the original disc to copy on...
Hi pjhmulder
Assuming MS Money 2001 and 2003 are compatible with W 7 , you could install MS Money 2003 on the new computer and copy the files from MS Money 2001 on the old computer to MS Money 2003 on the new computer . Make sure you don't erase the MS Money 2001 files before transfer has successfully been executed .
Best regards ,
fanaudi .
Aug 12, 2011 | Microsoft Computers & Internet
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
indicates that the hard drive is starting to fail
save everything to an external hard drive
have the system tested by an computer repair shop and if faulty install a solid state hard drive that has no spinning disc
also up grade to win 7 operating system as win xp is no longer supported by Microsoft and many other products are not compatible with win xp
Aug 10, 2017 | MSI Wind U100-423ES Notebook
I have a new computer with Windows Vista. I have
No it looks like they stopped the support at the old one, this means they did'nt make any drivers for the old one to function on vista.
Vista uses a very diferent driver model than xp does.
The drivers for xp won't work in any way on vista.
Sep 19, 2009 | IMSI QuickVerse 8 Deluxe (QUICKVERS8E) for...
My new computer runs Windows Vista (my old one ran Windows XP) but my original start up disc for my HP PSC 1402 printer/scanner is only compatible with Windows 98/me/2000/xp. Can you supply me with a Vista...
We have you covered! Simply click on the link below , and select the download for Windows Vista ( it is the last one on the list) .....after the download is complete , launch the setup and you should be good!
http://www.siliconguide.com/drivers/device/93/
Oct 01, 2008 | HP Office Equipment & Supplies
Innovative Technology The Ultimate Film And Negative Scanner itns-500 Logo
98 people viewed this question
Top Innovative Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Innovative Office Equipment and Supply Expert? Answer questions, earn points and help others
