Question about Whirlpool GEQ9800L Electric Dryer
Start Button when turned on you can here it timing the dry cycle but when the start button is pushed it just clicks and won't start
    Scholar:
  • 163 Answers
Could be one of several things. There is an interlock switch that turns off the machine when the door is open. There is a thermal switch that turns off the machine when it thinks it is too hot. There is usually a big start up capacitor in the motor circuit that might be defective. The timer runs off a different circuit than the motor. Unplug your dryer and use a multi-meter to test the switches. That's the easiest thing to verify first.
Posted on Feb 11, 2014
  • 262 Answers
SOURCE: my dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Posted on Dec 29, 2007
vanni7
  • 163 Answers
SOURCE: Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Posted on Jan 04, 2009
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
mcgyver468
  • 710 Answers
SOURCE: My dryer won't start, but I think the cycle button won't engage.
THERE IS A SWITCH THAT IS LOCATED ON THE OPPOSITE SIDE OF THE DOOR. SOME OF THESE SWITCHES ARE OF THE PLUNGER TYPE. TRY PUSHING THE PLUNGER IN WHILE STARTING THE DRYER, MAKING SURE THAT NOTHING IS IN THE PATH OF THE ROTATING DRUM. IF THE DRYER STARTS, THEN EITHER ADJUST OR REPLACE THE PLUNGER SWITCH. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. GOOD LUCK
Posted on Sep 22, 2009
  • 396 Answers
SOURCE: Nothing happens when I push the start button.
There is a micro switch on the door to stop the dryer when you open the door during normal operation. Unplug the dryer and locate the switch by visually inspecting around were the door contacts the dryer and identify if you can remove the switch without opening the dryer top. If you cannot remove the switch from the front try to access the switch by lifting the top of the dryer cover off. Unplug one of the wires and touch the wire connector you removed to the other connector on the switch using electrical tape to insulate and hold it in place. Plug the dryer in and see if it works. If it does you need to order and replace the switch. If it does not the start switch could be bad and you will need to test it with an Ohm Meter which will be the safest way to test the switch.
Posted on Jan 21, 2010
Testimonial: "I appreciate the quick response on the problem with my dryer. The clear instructions will give me the ability to check it out. Thanks!"
When i push start on my dishwasher my drying light turns on
What cycle are you running? Can you change the cycle? Does the light turn on solid, or does it blink a few times? And are you sure it is the Drying light, and not the little "lock" symbol above it? Maybe you have the control-lock function turned on. Or maybe you just need to press the Cancel button to terminate the current cycle, so you can start over.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 27, 2014 | Kenmore Dishwashers
Dryer is humming when I push the start button, nothing else.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
When i push the start button,it doesn't light up and start. The normal cycle and the other cycles lights work but it won't start. If i push hi-temp wash and heated dry several times, all lights will come...
i would replace the key pad it sounds like since everything else works.. so you hit the normal wash and start the dishwasher sits there for a min or two and turns off.. Its not recognising the start button
Sep 03, 2009 | Dishwashers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEQ9800L Electric Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
