Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp4663 stand by light
When I turn the television on, first the lamp light blinks. After that, the stand by light comes on and stays on. I have already replaced the color wheel and the lamp.
    Problem Solver:
  • 12 Answers
I recently had this issue on my Samsung HL-R4667W. Did the new lamp (phillips) but it still wouldn't light up and was flashing the lamp light and then stanby. I started to remove the rear covers of the TV thinking maybe the wheel or ballast finally gave out. After removing the lower cover I noticed a wire hanging at a unusual angle from a circuit board. I touched it and it fell off. Traced the wire back to the main control board and found that it was a ground wire. I re-soldered it to the board and the TV fired right up. My other lamp was fine too. I hadn't moved the TV in 4 years and only once since I bought it in 2006 so I can't think of anything that would cause it to come loose short of bad soldering from the assembly line. That was a year ago and it works fine still.
Posted on Apr 02, 2014
ladywinn
  • 5138 Answers
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
Posted on May 01, 2010
  • 31 Answers
SOURCE: TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Posted on Aug 14, 2008
  • 304 Answers
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Posted on Jul 16, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
SOURCE: replaced lamp & color wheel, no picture
Hi Jaldrova, I have the exact same issue (I changed the color wheel and lamp) and now my immage is off center. Did you ever find a way to adjust the position of the immage? Thanks
Posted on Nov 15, 2009
Samsung h1s6187wx wont turn on
Two things to do in order: remove and inspect lamp to see it is not shattered inside-----with it out also inspect the color wheel that faces it to see it is not shattered or missing pieces.
Jun 07, 2012 | Samsung HLS6187WX/XAA
My Samsung 46in DLP turns on but within a few minutes it truns off and the timer, lamp and red stand by/ temp lights blink. Any Ideas?
The blinking lights usually indicate that the lamp is faulty or burnt out. In this case a new lamp would be required. The lamp in your projector set should last around 3-4 years of typical use. If your lamp is at the end of it's life you may have noticed a gradual reduction in brightness over the last few months. In this case if it's still in warranty contact Samsung to arrange for a replacement lamp.
Occasionally the lamp may not come on even when it is not burnt out. You could try turning the power off for 60 seconds on the back of the set. The other possibility is that the lamp is loose. Refer to your manual on replacing the lamp and follow the instructions removing the lamp and then put it back into place. If neither of these work you will need to get a new lamp.
Feb 28, 2011 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
