Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
01 dodge interpid engine dies at idle or while driving. Check engine light flashes on then off . No codes set. I replaced the crank sensor. still have the problem. 2.7 liter engine.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 56 Answers
Check fuel pressure, and earth point for ecu
Posted on Feb 10, 2014
Tcs light flashes and p0340 code
P0340 code means "Something" is wrong in the timing...
from CMP (Camshaft Position sensor) to the crankshaft bolt.
Very first thing, verify connectors are clean and shiny.
clear all codes, even hard codes.
Nov 23, 2013 | 2005 Mazda 6
1999 Intrepid with a 2.7 engine dies after driving 15 miles. pull over and it starts right up and runs fine again
This Symptom (WITHOUT)> Check Engine Light on Is indicative of a FUEL PUMP INTERMITTEN Failure/FUES FILTER CLOGGING Problem, But (WITH Check Engine Light ILUMINATED)< The Vehicle Must Be Connected to A CODE/ Diagnostic Tool to Interpret What Code and Where the Problem IS Located. I am Sure this WILL Help LEAD you to Your Problem.
Oct 20, 2010 | 1996 Dodge Intrepid
What does the p1391 code on a 99 dodge ram 1500 5.2l v8 meen
check engine light and code P1391 crank or cam position sensor
The above can cause rough idle on the Dodge Ram 1500 5.2L V8 Engine.
Can try to replace the sensor, but verify that the wires are ok first.
Aug 12, 2010 | Dodge Pickup Cars & Trucks
Why does my 200 Dodge Caravan keep stalling? Is it the computer?
If it won't idle but it will run fine when you drive it and only stalls when you come to a stop then it is possible be the idle air control valve. The computer controls this idling and this will not always set a check engine light on or set a diagnostic trouble code.
Apr 14, 2010 | 2000 Dodge Caravan
Car idles fine, dies when accelerated
It is suggested that you always start with first code first. not knowing what code came first, and my experience with Dodge. i have found that them symptoms resemble a map,sensor/check vacuum hose and vacuum.
Apr 06, 2010 | 1998 Dodge Intrepid
1997 DODGE RAM 1500 360 VERY LOW IDLE
I think you have ruled out the engine with all the parts you have replace. The transmission torque convertor is in lock up mode all the time. The engine is having to hard of a time to stay at the normal idle. The over drive clutches and soleniod are most likely damaged in the transmission.
I think you should take the vehicle to a trasnmission shop , The can check the torque convetror soleniods and pressure control soleniod.
The oil light coming on bothers me. I know you have the rebuilt engine in the vehicle but I think the oil pump in the engine is starting to go out or could be weak. The lower bearings connected to the crank shaft might be starting to leak. Have the oil pressure checked .
Mar 19, 2009 | 1998 Dodge Ram 1500 4WD
Truck dies when i stop or slow down
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Feb 17, 2009 | 2003 Dodge Durango
Car dies
Look on the front of your transmission from the front of the car on the drivers side there is a module there. It sticks out of the front of the trans and should be white with a blue clip. Unplug that sensor and see if the car idles as you are driving it . This sensor is called a idle sensor, car idles until its stopped like at a light or something. Replace this sensor if unplugging it to see if this helps the car run works.
Aug 29, 2008 | 1991 Oldsmobile Cutlass Calais
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
27 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
