Samsung WF 8604 ngw - Washing Machines
Where we buy Samsung Washing Machine replacement part i need a (motor carbon brush) Model for WF-B1061
samsung authorized repair shop spares
go google to samsung spares direct
find an appliance repair shop as the motor may be generic or have generic brushes fitted
Sep 30, 2015 | Samsung Washing Machines
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
Samsung wf-b1061 give 4e errore
Here is the owner's manual:
http://www.manualslib.com/manual/147752/Samsung-Wf-B1061-User-Manual.html?page=10#manual
It says in troubleshooting section error 4E is a water supply issue. The screens on the watervalve may need cleaned. Remove supply hoses on back of machine to clean them. If no improvement check water pressure coming from supply hoses. If pressure is good watervalves may need replaced.
Jan 07, 2013 | Washing Machines
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
I need a user guide of samsung wf-c863
user guide of samsung wf-c863 go there and click"download pdf" the answer the qusetions and it should work.
Dec 14, 2010 | Home
Operating of samsung WF-B1061 washing machine
You can download the manual direct from samsung just go to their site type in your machine and download.
May 22, 2009 | Samsung WF317AAG Front Load Washer / Dryer
Samsung WF 338 washer
Hello.
These are usually shipped with a number of "shipping bolts" to lock the drum in position during transit. If they are not removed when it is installed, then the washer will behave exactly as you describe. Check the manual or look for a sticker on the back or the washer showing which bolts to remove,
-ellie
Jun 26, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
