Question about Epson PictureMate Flash PM 280 InkJet Photo Printer
Working its coming the printer ink pads are at end of their service life
Eppson pic mate pm 235 is not
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Install new ink pads.
Posted on Mar 20, 2014
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
rioglen
  • 95 Answers
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Posted on Sep 10, 2009
SOURCE: The printer's ink pads are
The Printer's ink Pads are at end of their Service life
Posted on Feb 25, 2011
  • 6 Answers
SOURCE: EPSON STYLUS T13 printer's ink
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME .INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.INK LEVEL LEVEL ALWAYS SHOW 100 %NO WASTE INK PAD COUNTER MORENO NEED TO WORRY WHILE PRINTING MORE PRINT JOBSnow no more ink cartiledge not recognise problem
Posted on Jun 19, 2011
masudkaysar
SOURCE: The printer's ink pads are at the end of their service life. Please contact Epson support.
Posted on Jan 12, 2013
Epson pm 245 ink pads
The printer's ink pads are at the end of their service life.please contact Epson support.
Jun 28, 2013 | Office Equipment & Supplies
Printer's ink pads are nearing the end of their service life.
The printer's ink pads are nearing the end of their service life. Please contact Epson support.
Dec 04, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson pm 235 ink pad are at tha end of their service life
Picture Mate PM235
Jun 11, 2012 | Office Equipment & Supplies
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
Service required error in epson picturemate 235
Mar 16, 2011 | Epson Office Equipment & Supplies
Service reqired The printer's ink pads are at the end of their service life. Please contact Epson support.
Not all the ink pulled from the ink-cartridges gets sprayed onto the paper.
Some of it ends-up in an absorbative pad.
Eventually, those pads get saturated with ink, and need to be "serviced".
Take the printer to any qualified computer-technician, for that servicing.
Feb 26, 2011 | Office Equipment & Supplies
Epson PictureMate  Flash PM 280 InkJet Photo Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
