Question about Tricity Bendix AW1000W Front Load Washer
Washing machine gets stuck each time on Rinse, Drain or Spin cylce and can't open door!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
The drain pump cant get the water out of the machine check it and also check the filter maybe something stuck in it
Posted on Feb 10, 2014
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Washer won't spin
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Goes through wash rinse and spin lights come on at same time machine stops does not rinse or spin or drain
pump or outlet hose blocked, there should be a door at the bottom front of the machine to access the filter and possibly a small capped hose to drain the water before opening the filter.
Nov 01, 2010 | Bosch Washing Machines
Good morning, I hope you can assist me today. My GE washing machine will start a cylce and run through til it hits the rinse cycle then stops. It will do this on all types of cycles (delicates, permanant...
your lid switch is most likely the culprit. its wired into the circuit so that the unit will not spin, etc while the lid is open to avoid broken limbs etc from unsuspecting, and uneducated arms, etc.
it will not allow the unit to pump nor spin out until it is repaired/replaced.
Aug 03, 2010 | GE Washing Machines
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing machine doesn't spin
if machine doesn't drain, then it won't spin!
check the filter and check no foreign object stuck in pump impellor
Jul 09, 2008 | Washing Machines
My washing machine gets stuck after rinse cycle
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Mar 30, 2007 | Frigidaire GLWS1339CS Top Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
