Question about Nuova Simonelli Premier Maxi Espresso Machine
Program error I put the machine into program mode and go through the steps of dropping the shots and hitting the stop button, then hit the stop button twice to lock it into memory. I push the selected button that was programed and the shot pours and then the constant pour button flash's and the the shot has to be manually stopped with the stop button. How do I fix this program error? Could the board be bad? Could the flow meters be bad? Help Help Help.. Thank you
    President:
  • 1,618 Answers
Yes the flowmeter needs to be checked the impella or head needs to be replaced.
Posted on Apr 05, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Dose buttons flash, and won't pour, after reprogramming.
It is possible that the flowmeter is damaged, That is usually the problem when the machine will not hold programming.
Posted on May 20, 2010
EsWorld
  • 1618 Answers
SOURCE: Whenever I try and pull a shot on my espresso
There is a problem with the flowmeter, it is located under the drain tray with 3 electrical connectors to it. The flashing means it cannot read the magnet on the wheel. You might have to replace the flowmeter. First try programming a button on the side that is not working, if it does not hold the program then it is the flowmeter.
Posted on Sep 23, 2011
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
How do I program the scanner. It keeps telling me there is an error when I enter anything. Any help would be greatly appreciated.
I have one of these scanners they are kinda hard to program uniden could of made it simple.....Ok you have to hit your function button first...Then hit your e button enter button the enter button and it will go to program...The enter button and the program button is the same just go to your enter button. e button this will put your scanner into program mode...then you can start entering your frequencies...if you don't have it in program mode it will show error...If you have any more problems you can e mail me randymarr570@msn.com
Jul 16, 2011 | Uniden BC72XLT Handheld Scanner
CANT TUNE IN MY SCANNER
put your bc72 in program mode.. hit you e button your enter button..but first put your scanner in function mode... then hit your enter button this will put your scanner in program mode and you can start entering your frequencies into it....if you have any problems biddy mac you can email me at randymarr570@msn.com................
Jul 02, 2011 | Uniden BC92XLT Handheld Scanner
Whenever I try and pull a shot on my espresso machine, the "constant flow" led starts blinking, and water will not stop dispensing until I hit the "stop" button (does not stop...
Jun 03, 2011 | Nuova Simonelli Mac 2000 Espresso Machine
Message reads: wrong cartridge but I have put in 2 new canon cartridges and the message won't go away...getting really aggrevated!!!
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Mar 05, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
Oct 13, 2009 | Canon SmartBase MP360 All-In-One InkJet...
How do you change the dosage time on a Cimbali Bistro espresso machine
You can do it one of 2 ways, if the machine has a display then you can go through the program mode by removing the face cover on the display and pressing the programing button then navigating to the dose setting menu, then select a button and change the numbers there. Note the numbers are not ounces rather flowmeter cycles.
Second way is to hold down the stop button for 8-10 secs you will notice the lights flashing and you will hear a faint beeping every second, press the button to program then hit stop when you get thew correct volume, when done with all buttons hit the stop again.
Oct 06, 2009 | Espresso RMI La Cimbali Espresso Machine
My Canon Pixima mp760 printer has the ink abosrber almost full. Can you explain in plain english step by step how to reset the counter to 0. Thanking you. Sharon Fitzgerald
This is for MP730, maybe it's similar Good luck
  • Hit “Copy” Key
  • Hit “#” Key
  • Hit “0′ button
Jun 01, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Nuovo Simonelli VIP 2 group
Hold down the stop button and the continuous run button. lights will blink indicating program mode. Push one of the buttons that you are trying to program, when the desired quantity is reached press stop button. When all buttons are programed hit stop button again.
Jan 07, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Espresso extraction time
You will need to reprogram the computer. To do this, it is relatively simple. take your grounds and tamp into your portafilter (I usually start with a double). make sure that you tamp it correctly.
Then, hold down the start/stop button until you see the lights flashing on the panel (if you want to program both groupheads at the same time, then hit the start/stop button on the other side as well.) Then with your portafilter inserted in the grouphead, hit the button that you would like to represent your double shot. you should see a water stream about the width of a cooked piece of spaghetti. After around 18 seconds to 22 seconds, you should have your shot levels filled. then hit the button that represents your 'double' shot to stop it. then hit the start/stop button. You will see the start stop button flash a couple times and then turn off.
That should do it. remember, that the preferred timeframe for a shot of espresso is 18-22 seconds. Your setting on the coffee grinder would then need to be set to make sure your getting a full shot in that amount of time.
Good luck
Dec 09, 2007 | Astra Mega II Espresso Machine
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
77 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
