Question about Samsung WF330ANB/XAA 4.3CuFt 9-Cycle Washer - Blue
Makes straining noise, does not start
Timer does not move, water does not fill, washer does not start
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Check the door lock switch does it lock when you close the door if not than its the door lock
Posted on Feb 10, 2014
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
The dryer starts fine but the motor doesnt even start when i try to use the washer.
If it fills with water it could be the fill switch, not sending a signal to the timer. If the timer isn't moving it could be the timer which sounds the most likely, I would need more information but these are great machines. If it is not filling with water check for water at valves or hoses and check for the power cord plug making sure it is still plugged in correctly.
Nov 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
The washer fills only with cold water. if warm or hot is choosen, you hear a noise (sounds like something is straining) but no water comes thru. but the washer continues as if water has come thru.
try taking off the hot water hose(from the wall) and make sure the hose has no obstructions. My did the same thing,after I cleaned it out it worked fine.
Aug 17, 2010 | LG WM1812C Front Load Washer
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Top load kenmore - washer
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
Samsung WF330ANB/XAA 4.3CuFt 9-Cycle Washer - Blue Logo
122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
