Question about Jandy Pool & Spa
Need service manual for Jandy AE2500T
I turned the heat pump temperature down for awhile and now I can't restore it to operational status
    Top Expert:
  • Jandy Master
  • 8,163 Answers
Try turning all off then back on
Posted on Nov 16, 2017
4 Suggested Answers
  • 22 Answers
SOURCE: Can't shut down the main
The relay is probably bad. If you open up the main outdoor panel, you can watch the bottom of the relay for the pump, ususally on the upper left of the relay cluster (black). Watch for a small tab popping out when turning on/off. If you don't see it, the relay is bad. This assumes you hear a click when doing this.
Posted on Jan 01, 2009
  • 246 Answers
SOURCE: gas heater and heat pump chiller control problem
NO. BUT YOU CAN CONTROL WHAT EQUIPMENT TO COME ON BY INSTALLING A RELAY FOR EACH ONE THEN ASSIGN A AXUILIAR BOTTOM IF ANY LEFT
Posted on Nov 18, 2009
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Posted on Jul 08, 2010
Water Temp
Sounds like the thermostat is bad on your heater.
Rod
US Parts Center
May 03, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy AE-TI H20 error message - pool not heating
just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Nov 13, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
High Refridgerant Pressure
I was able to find the manual online which had the solution in the troubleshooting guide.
Jan 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool & Spa Logo
61 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
