Question about Makita HR2811F 1-1/8-inch Rotary Hammer
I need to change the oil on my makita hr2811 what grade do i need to use
Hello what is the capacity oil of honda xr 250 model 2005
The oil capacity of an XR250R / L is 1.3 litres if you are only changing oil.
If you are changing oil and filter you need 1.4 litres.
The oil type should be API grade SF or SG multi-grade oil for motorcycles.
Viscosity 10W-40 as standard but 10W-30 ,20W-40 or 20W-50 are acceptable dependent on the temperatures where you live, your supplier can advise on this.
May 16, 2011 | 1998 Honda XR 250 R
Ive got a Makita concrete saw DPC 7311,it says a mix of 100:1 but thats alot ?
The manual says to mix it 100:1 if using Makita high performance oil or 50:1 using regular Makita 2 stroke oil. I'd go 50:1 with non Makita oil too.
Here is a site to download a pdf manual if you need it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 18, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
What grade of oil doe a 2007 Suzuki Reno take. 5 30 or 10 30
Suzuki recommends 10w30 grade oil and it will need about 2.4 quarts of oil without a filter change and 2.6 with a filter change.
Dec 19, 2010 | 2007 Suzuki Reno Hatchback
How often do you change the motor oil? The motor oil filter? The automatic transmission oil and filter? What type of motor oil should be used?
Oil change recommended is every 3,000miles / 5000km for local short running around. If you clock up the miles quickly then extend the oil changes to 6,000miles /10,000km
Oil filter is every second oil change.
Use reputable multi grade oil 15W/40 or similar, Do not use standard SAE 30 single grade oil. You do not need to use synthetic / semi-synthetic oils either.
Oct 20, 2010 | 2002 Nissan Maxima
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
We have dcs6400 and this tool is making a huge noise when we start it and also the tool is looked as it gets overheated very soon even on idle running. please suggest the grade of oil to be used along with...
2-cycle oil mixed at 50:1
1 Gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 Liters of premium fuel to 80 CCs of quality 2-cycle oil.
Your OM can be found here:
Makita Canada Inc:
http://www.makita.ca/data/upload/tools/dcs6401%20F-E.pdf
Good Luck. HTH
Lou
Feb 23, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
How often do i need oil change on a 2000 323i bmw?
Your car holds almost 8 quarts of oil and it doesn't need changing untill you drive 8,000 to 15,000 miles
Dec 24, 2009 | 2000 BMW 3 Series
Makita mac5200 compressor doesnt like the cold would like to swap oil for synthetic what should i use for winter
hi buddy compressor oil is oil there is no synthetic its one type really i will run on any compressor oil its not an engine you can buy oil on ebay buddy
Oct 14, 2009 | Makita MAC5200 Electric Powered Air...
Makita HR2811F 1-1/8-inch Rotary Hammer Logo
74 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
