Question about GE Profile Harmony DPGT750EC Electric Dryer
Press the power button and nothing
The dryer would not come on when power button pushed. If I wash clothes and the info is relayed from washer to dryer it will come on. When it is on all of the screen/functions work and it dries. Now...some days the relay will not work nor will the power button work. Not sure if it is a door problem the light inside the dryer does not work now either. Sometimes I cannot get it to come on at all..then try the next day and push the power button and it comes on like there was never a problem. When I push the power button it does nothing...no sound, no clicking noise, no beeps when it acts up. It is not a constant issue...it just started doing it more and more and then laundry gets backed up. Not sure if is a simple fix or if the main computer board is going out?
  • 3 Answers
SOURCE: dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Posted on Feb 18, 2009
  • 3074 Answers
SOURCE: Dryer is plugged in and the power seems to be
this may help;
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 24, 2010
Testimonial: "Thanks a million. Yup, that was indeed very helpful, and exactly what I needed. You directed me to the perfect solution. Thank you, thank you."
  • 9 Answers
SOURCE: i repaced the felt and slides to fix a loud noise.
Using a screwdriver or similar, slender object, push the door switch in with door open. Try to start dryer. If it doesn't start it is quite possible that the switch was not connected when you finished working on it. Check to make sure the wires are connected to the switch.
If both leads are connected, you can check the switch with a continuity tester. (About $3.00 at your local big box store should you not have one). With the dryer UNPLUGGED connect the clip to one pole on the switch. With the probe, touch the other. The light on the tester should only go on when you push in (with screwdriver) to activate switch. If the light doesn't go on, your switch is bad and needs to be replaced.
Posted on Jan 29, 2011
  • 11 Answers
SOURCE: I have a DPGT750ec0pl dryer
yes
Posted on Jul 26, 2011
  • 3640 Answers
SOURCE: Dryer was squeaking and now it just clicks when you push the start button
if motor will not run. check it out! it may be seized or in need of oil on end bearings. ( each end of motor ) just get access to the motor.
Posted on Feb 01, 2012
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
The "On/Off" button is stuck pushed in and the light stays on. Now the "No Spin" button is stuck in the pushed in position also and I can not dry clothes.
Hi Cindy,
I think that you're going to have to remove the control panel and see if you can get to thebuttons from the back. Make sure that power is off.
http://nodevice.com/manual/haier
Aug 06, 2015 | Haier XQG50-11 Front Load Washer / Dryer
The Dryer won't start. Power light just flashes red on and off
There are too many problems that it could be, anything from the Button going bad, to the Door Shut Switch being defective, to the Motor, Relay inside the circuit board, to loose wire during the move, and the list goes on and on. Unless you can test each component that sends the START signal, nobody will be able to assist you with the information you have provided.
Mar 01, 2014 | Hotpoint Ariston AWD129 Front Load...
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Mar 02, 2018 | Kenmore 24032\24036 Top Load Washer
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
GE Profile Harmony DPGT750EC Electric Dryer Logo
41 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
