I have a Hiland Model #HLDS01 patio heater. I have used it only twice because each time I have used for about one hour time the gas cylinder is empty. I have shut off the cylinder valve both times. When I try to ignite it the next day, the cylinder is empty. Both times I have used a full cylinder.
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Wather heater will not ignite
You'll probably need to ignite the pilot light before it will allow gas to flow for the heater to ignite and warm the water.. Most controls have a Pilot position that you switch it to , than using a long match .. locate the pilot light in the access opening at the bottom and get the pilot light to stay lit.. Hope that helps...
Posted on Aug 16, 2008
SOURCE: Patio heater won't stay lit
I had this same problem - here's how I fixed it...
First: Never modify the safety features of your heater as has been suggested elsewhere on this forum. Modification of these features may allow the heater to work, but greatly compromises the safety of anyone near the heater.
The problem with the heater shutting off is most likely due to not enough gas flowing through the pilot orifice (this orifice is almost as small as the diameter of a human hair). When this happens, the pilot flame does not burn vigorously enough to activate the thermocouple. Hence, the thermocouple shuts off the gas and the burner goes out - usually you'll hear one "click" when this happens.
This is a maintence thing - meaning you may have to do this as a seasonal activity.
Here we go....
(1) Shut off the gas at the tank - or remove the tank entirely.
(2) Remove the screws that hold the burner shield and top shroud from the unit - set it aside.
(3) Remove the control knob - it just pulls straight off.
(4) Remove the panel immediately behind the knob you just took off. This will expose the gas valve assembly.
(5) Remove the cover that encloses the bottom of the pilot light/igniter (assembly). This will expose the bottom of the pilot assembly.
(6) Remove the screw holding the pilot assembly - there is a small hex nut on top, but under the burner that you'll have to hold to prevent it from turning. This will free the pilot assembly allowing you to gently pull it out of the pilot assembly housing. DON"T pull hard or you may break the gas line or thermocouple.
(7) Remove the hex nut that attaches the gas line to the pilot assembly and gently pull the gas line out. At this point, to ensure you have gas flowing through the pilot gas line, you may want to re-attach the gas tank, turn it on, gently move the gas line as far away from the spark ignitor as possible, temporarily replace the control knob, and turn the knob to the "Pilot" position & push it in. DO NOT DO THIS ANYWHERE NEAR AN OPEN FLAME OR A LIGHTED CIGARETTE! You should be able to hear a hissing sound as the gas flows. If you do not hear it, the problem may be with your gas valve, and if that's the case, I'm sorry this procedure likely won't solve the problem.
(8) Remove the pilot light tube (orifice) from the mounting bracket. There's a hex nut on the back side that holds it in. Be careful not to damage the hex nut or the threads. You'll need a pair of pliers (to hold the bracket) and an adjustable wrench for the hex nut. Make note of the orientation of the pilot burner diverter so you can put it back together the same way it came apart.
(9) Using a blast of compressed air, blow air through the pilot orifice. You should be able to see just a very (and I mean very) small pin-point of light through the pilot burner. If not, use a single strand of very fine wire - like one strand from a 18 gauge braided electrical wire - and run it through the pilot orifice. Carbon build-up can clog this orifice - which can prevent the pilot from burning vigorously enough to heat up the thermocouple. Cleaning it out periodically will likely solve the problem.
Put everything back together in reverse order as noted above - making sure your gas fittings are tight and don't leak. Once it's all back together, light the pilot flame as normal and once the thermocouple heats up, the heater should work like a charm.
Posted on May 25, 2009
SOURCE: charmglow gas patio heater
charmglow heater,,my pilot lights,but when we turn knob to #2 the pilot goes out.tank is full,is it the regulator or the thermostat control valve?
Posted on Jan 10, 2010
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
Nov 05, 2014 | Patio Heaters
Hear sound after few minutes and then shuts down
Check the gas cylinder is full and using propane (butane is not good in very cold weather). Make sure there are no leaks, to do a leakage test see patio heater problem solving. If all OK the most likely cause will be a worn thermocouple, this can cause the burner to turn off.
Oct 26, 2011 | Stainless Garden Sun Steel Propane Patio...
Gwt501a won't light
This can sometimes happen if the propane tank runs empty or the unit has been setting for some time.
It is typically the regulator is stuck and will not allow gas to pass through the regulator.
You may need to clean your regulator with some WD-40 or sometimes just tapping on the regulator several time with allow the diaphragm to start working again.
Here is a link to the manual;
http://www.bestbuypoolsupply.com/media/GWT501A-manual.pdf
Oct 21, 2011 | Uniflame GWT501A Open Flame Patio Heater
Model JDS032 Tabe top Heater. No gas flow
Start with the cylinder, make sure you have plenty of fuel, if down to the last bit it can slow right down. Make sure it's propane (butane will not work in cold weather) and check for leaks. Found this site very useful patio heater problem solving, they have lots of help pages.
Sep 11, 2011 | Stainless Garden Sun Steel Propane Patio...
Not getting any propain to my patio heater
First check the gas, connect the regulator to the cylinder but unclip the hose and do not light the heater. Turn the gas on for a second to see if the regulator is working OK. Next make sure there are no blockages in the pipes up to the burner. If all clear then vent the pipes to clear all air. If still not getting any gas the problem could be a faulty tilt switch cutting the gas supply or a worn thermocouple. Short out the tilt switch to test and if not fixed then change the thermocouple. Found this site very useful with tips patio heater problem solving.
Sep 01, 2011 | Rta International Patio Heater
I can light the pilot light, but there is no gas flow to the heating element, thus heater will not light. Looking to replace control value, but can't locate one online. Where can I go to order new...
Gas control valve are very robust and will last last for years. If the pilot is not lighting the first thing is to check the fuel line from the cylinder up. Always run a leakage test as this will cause problems if you have a steel pipe that runs inside the pole - these can get loose and gas leaks from the locking nut. Use some plumbers tape/seal, for info on problem solving and leakage test see patio heater guide. Also check your tilt switch and try shorting it out before changing the gas valve.
May 12, 2011 | Napoleon Lifestyle Collection Bullet Model...
Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Nov 15, 2007 | Coleman (5040B750) Patio Heater
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
