Question about Uniden DECT 6.0 Cordless Phone ID
Disconnects Calls that we originate or come in are both disconnecting. These disconnects are not the fault of our service provider. What could be causing this?
  • 119 Answers
Make sure all connections are good, check line cord and make sure the little clips are still there, could be loose connection. And if battery's are old. You have to build a life to the battery's, if you keep putting it back on charge all the time your battery life span will be shorter. You build the life of the battery, by the way you charge them, if you only let it discharge for 5 min. and keep putting it back on charge the it will start cutting off after 5 min.
Posted on Mar 20, 2014
Are boards that connect to tcon board via ribbon cables a replaceable item?
The T'Con board you've replaced is either a damaged one or not with exact number as original. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 25, 2016 | Televison & Video
And i cant receive calls
Contact your Service Provide , to check your all paid up, not disconnected ! If you can make calls , then you do need their help.
Mar 16, 2015 | Cell Phones
Calls
I would go to your cell phone provider and ask what is going on with your cellular service. Or get a completely different cell phone with a new provider.
Jun 29, 2013 | LG VX8350 Cellular Phone
Htc 1s service is disconnected
Hello Dear:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 18, 2012 | Cell Phones
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
No dial tone unable to make or receive calls
Sounds like either your line was disconnected or you have a software problem with the phone.
I would call your phone provider's tech support or bring it to the nearest store location. If they look at it and it's a problem caused by something that is NOT your fault, they should replace it for free.
Hope this helps!
Please rate my solution!
- Frankie
May 06, 2011 | Cell Phones
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Rollover of incoming calls
this is not a internal problem, the problem is your telephone (dialtone) provider. they are the ones that control the hunting of your telephone lines..
Feb 12, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
