Question about Gbc HeatSeal Ultima 65 Laminating System
On my ultima 65 You have to push the reverse button before you hit the forward button then it will only run about 6" then stop
GBC Ultima 65 stays at the same speed cant adjust
You may have a problem with the motor or control panel switch membrane(a rubber sleeve under the buttons). Does the speed light on the panel move when you push the faster-slower buttons? If the light doesn't move it is probably your panel. If the speed light changes,but the motor doesn't change, the motor may be faulty. Does it go in reverse?
Nov 09, 2016 | Gbc Office Equipment & Supplies
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Why does it tend to operate in reverse when the RUN button is pressed?
keypanel membrane needs to be replaced, this is the rubber membrane between the pushbuttons on the front panel and the printed circuit board underneath it. remove the keypanel from the frame (2) screws. flip it over and remove the (5) screws holding it together, replace the membrane and reverse the process. I do carry these it stock.
Westco laminating service 405-324-6092
Apr 17, 2015 | Gbc HeatSeal Ultima 65 Laminating System
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Goes in reverse when i push start button
The control panel switch membrane is dirty. You take the right side cover off, take the entire control panel off ( 2 philip screws). The take the control panel apart (5 philip screws) wipe off the connections on the pcb and also clean the "buttons" on the reverse side of the membrane switch. it will work, you still need to replace the membrane in the near future. dirty connection was giving false reverse signal. Westco Laminating Service 405-324-6092
Oct 10, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
Laminate did not come out it just went back inside on roller
warm the machine back up, get the glue sticky again, then work it off, either by going in forward or reverse, whichever works best for the given situation. Don't use anything sharp as the rollers damage easily....very expensive
Sep 09, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Gbc HeatSeal Ultima 65 Laminating System Logo
93 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
