Question about Frigidaire GLGF377 Gas Kitchen Range
OVEN WILL NOT HEAT UP NEITHER DOES BROILER
OVEN AND BROILER NOT WORKING
  • Official Brand Answer
  • 4,342 Answers
Good Morning Debbie, I regret to hear that you are having difficulties with your oven not baking or broiling.
I see that your question is listed under a gas range. If so, here are some simple troubleshooting steps that may help you resolve this issue:
  • First, please disconnect power to your appliance!
  • Next, locate the gas pressure regulator (typically located on the back lower left-hand side of your range) and verify that the valve is in the "ON" position. If the valve is OFF, it causes to shut off gas to your oven.
  • Reconnect power to your range.
  • Set time and select bake or broil option.
Should this prove to be unsuccessful I suggest reaching out to an Authorized Service Technician.
Thank you again for allowing Frigidaire to assist you.
Posted on Feb 20, 2014
  • Electrolux
    Electrolux Feb 20, 2014
    Debbie, since we are dealing with gas range and for safety, please be extra cautious!
4 Suggested Answers
  • 530 Answers
SOURCE: oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
Posted on May 28, 2009
SOURCE: the oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Posted on Aug 07, 2009
SOURCE: oven does not work- broiler does
When I turnt he oven on- it does not heat- but the broiler works just fine- Help!!!
Posted on Aug 26, 2009
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Oven not working
There is a separate element for the oven (bottom one) and the broiler (top one) It sounds like the bottom heating element is burnt out assuming this is an electric oven.
Nov 23, 2008 | Ovens
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Frigidaire GLGF377 Gas Kitchen Range Logo
64 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
