Question about Danby Portable Air Conditioner
Portable air conditioner only leaks when in dehumidifier mode
Hi, My Danby portable air conditioner works fine in every mode with the exception of dehumidify mode. When in dehumidify mode it doesn't drain into the reservoir like it does in every other mode. Instead, the water pools near the front of the unit. Any help would be appreciated.
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Posted on Feb 15, 2007
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
heatman101
  • 43501 Answers
SOURCE: Danby DPAC13009: Light yellow instead of orange for dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
  • 36 Answers
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
Posted on May 27, 2010
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
Danby air conditioner mode dpac8099 need manual
Hi There,
The owner's manual for that portable air conditioner can be found at the link below
http://www.danby.com/en/CA/page.php?c=4&id=14&p=791
Thanks and have a great day!
Jul 11, 2012 | Danby Heating & Cooling
Need owners manual for Danby DPAC10060(R)
Gwen, here is a link to the Owner's Manual for your Danby, Model DPAC10060, Portable Air Conditioner. You can download and print the manual for future reference.
http://pritchard.dyndns.org/mediawiki/images/Danby_DPAC10071_EFOM.pdf
Hope this helped you.
Jun 30, 2011 | Danby DDR2509EE Dehumidifier
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
I have a Danby portable air conditioner: DPAC7099. What is the garden hose for?
The drain hose is to drain the unit when in dehumidifier mode. You can get the manual on the link below just enter the # code then click on download manual. Page 10 of the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Jun 01, 2010 | Danby DPAC7099 Air Conditioner
May 27, 2010 | Danby DPAC8020 Air Conditioner
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
I have a Noma/ DeLonghi portable air conditioner. 3 Modes-fan-dehumidify-air conditioner.When I try the Dehumidify or air conditioner mode the mchine strains to start up and then blows a fuse. Fan still...
Compressor is not starting, it could be a bad or shorted run capacitor, start capacitor and relay, low voltage, loose or disconnected wire or a shorted compressor.
Aug 22, 2009 | Heating & Cooling
Excessive water draining from portable A/C
It appears that you have changed the location of the unit, I mean have you relocated to an area whwre the humidity is high, usuallly coastal areas have high humidity.If not is there a door that is being constantly left open causing a lot of fresh high humidity air into the room
Jun 04, 2007 | Maytag Portable Air Conditioner M6P09S2B
Dehumidify mode also cools
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Danby Portable Air Conditioner Logo
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
