Question about GE JTP45 Electric Double Oven
Control panel lights all lit - GE JTP45 Electric Double Oven
Do I have to replace the control panel on the oven if it isn't lit?
Without a full schematic, and an understanding of electrical wiring, you have no idea if the internal 120 vac light is even on the same circuit as the control panel. Electric ranges are generally powered by 220vac, which means that both 120 lines are run through the unit.
you could have full power to the appliance bulb and have a blown fuse to the control panel, how much of the range actually functions at the moment would be important information to share.
Mar 04, 2015 | Whirlpool Gold 30 in. Double Electric Wall...
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
GE stove JSP40BB has digital readout all lit up. turning off power did not reset it.
Unplug the range.
Open the control panel to access the clock control.
Remove the wires from the control for 30 seconds.
Replace the wires on the control and plug the range back in.
If this does not clear the control you will have to replace the control.
Jul 24, 2010 | GE Ovens
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidaire self cleaning oven MODEL PLCF398DCC
you should be able to simply hold down the contro lock button for 3-5 secs, and it shoudl unlock for you
Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Control Panel doesn't work
Try fix found at  http://www.fixya.com/howto/h155060-dreaded_f7_error
It may work
Jul 15, 2008 | GE Profile JTP18 Electric Single Oven
Control Panel
there is no other way to get around that but to replae the control once agsin. It sounds like there are some stuck touchpads or the control itself is shorted. either way you need to replace it.
Aug 05, 2007 | GE JKP15 Electric Single Oven
GE JTP45 Electric Double Oven Logo
14 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
