Question about Jeep 2004 Grand Cherokee Laredo
Remote won't work
The remote will not work. Can only open vehicle with key. Only driver's side responds to power windows, side view mirror and locking/unlocking. Passenger/hatch doors and windows remain locked. However, without notice, when the driver's door is opened from the inside, all of the doors unlock/lock. Then without notice once unlocked will not lock automatically which leaves the hatch UNLOCKED. Cannot find a way to lock hatch mannually.
  • 28 Answers
Take the remote back to the dealer and have the codes erased and re-set. You can do this yourself if you want to. You can find the sequencing instructions on youtube for your year and model of jeep. sometimes it works and sometimes it doesn't. The dealer has a machine that hooks to your wiring harness and fixes it in 5 minutes but they charge you $50.
Posted on Feb 10, 2014
3 Suggested Answers
SOURCE: my driver side door electric lock switch will not lock or unlock unless my door is shut all other doors work
Pull boot on drivers side door, look for a orange wire cut in half!
Posted on Jul 19, 2012
  • 12 Answers
SOURCE: All doors except drivers side lock and unlock? with and without remote
Remove door panel amd see if something came loose also clean and lightly oil lock make sure nothings stuck inside also check fuses start with dcm fuse
Posted on Oct 02, 2012
Having issues with auto door locks, windows and side mirrors
Possible body control unit is faulty or broken wire or the unit is wet need to get it checked diagnostically to see what's going on
Jan 24, 2015 | Cars & Trucks
What could cause my power windows not to work?
Usually it is in the drivers window controller.There is a module that usually goes bad.
Dec 14, 2014 | Cars & Trucks
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
Sep 11, 2011 | 2004 Saab 9-3
Doorlocks dont work except from passenger side. mirrors dont work. windows dont work from anywhere
First, check all fuses to make sure that none are blown.
If the door lock switch works on the passenger side, then the drivers side door lock switch is probably faulty. Use a multi-meter to test the Drivers Side Door Lock Switch (Black and Pink/Light Green wires unlock the vehicle, and the Black and Pink/Yellow wires lock the vehicle)
If the switch is tested and found to be operating properly, you may have a faulty Body Security Module or Drivers Side Door Lock Actuator.
If neither of your Power Mirrors are working, you probably have a faulty Exterior Rear View Mirror Switch, Power Mirror Module, or blown Central Junction Box Fuse.
If none of your Power Windows are working, you probably have a faulty Accessory Delay Relay or a blown fuse in your Central Junction Box or a faulty Master Window Adjust Switch (all of the Power Window Switches feed through this Master Window Switch). If the Power Windows didn't stop working at the same time, you may have faulty Window Adjust Switches, or faulty Power Window Motors, this is very unlikely though. It would also be a good idea to inspect the wiring for any obvious damage.
Mar 15, 2011 | 2005 Ford F-150
Power door locks and driver side power window not working. Keyless remote will not open doors although when pressed, the interior lights come on so I don't believe it is an issue with the fob battery....
You can do it yourself.
Couple of times when you replace the remote battery, you might have them not working/ responding but just follow the procedure below.
Stand close to the car, hold down the open and close knobs for about 10 seconds. Press them at the same time for 3 seconds; then press the open button as the car opens.
The above procedure is applicable to a lot of car brands. It does not matter how many knobs you might have on the remote fob.
I have carried this procedure out on a lot of brands ranging from Honda, Toyota, Rover, Ford, etc. and it works perfectly well.
Good luck and Rate this.
Cheers
Dec 30, 2009 | 2005 Chevrolet Colorado
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Nov 25, 2008 | 2004 Jeep Grand Cherokee
Door chime and courtesy light (under side mirror)
     You have broken wires in the flexable harness between the door and the body. Pull the rubber boot back to inspect.
Nov 15, 2008 | 2002 Ford Explorer
Jeep 2004 Grand Cherokee Laredo Logo
62 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
