Question about Sunbeam Home
Flashing F2 on control - Sunbeam Home
One controller keeps flashing F2, what does this mean. It will not go to any setting on/off , raise or lower heat setting, etc.
All the information is here. It is a heating sensor error. There is also a video.
If you have a GE oven with an electric ERC, F2 means it is over heating. It is an oven. It is supposed to heat up. For the GE electric ovens and some others, F2 means it thinks the temperature is 590 degrees or higher with the door unlocked or 990 degrees with the door locked.Oct 11, 2015
F2 Google Search
Dec 10, 2016 | Ovens
Fix flashing f2
Unplug it, and wait 15 minutes. Then plug it back in. It should come on L. Let it sit another 15-20 minutes. You should be able to turn it up after that.
Mar 05, 2015 | Sunbeam Electric Blanket - queen
Flashing f2 preheated on a ge-spectra
F2 fault code indicates the oven exceeded 590 degrees with the door unlocked. This could be caused by a stuck relay on the oven control board or it could be caused by high resistance in the oven temperature sensor probe.
Feb 20, 2011 | GE Profile Spectra JBP95 Electric Kitchen...
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F2 IS FLASHING ON STOVE AND BEEPER WILL NOT STOP
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Apr 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Dec 13, 2008 | Kitchen Ranges
Flashing F2 while the oven is on
f2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Mar 16, 2008 | Hotpoint RGB745 Gas Kitchen Range
F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Dec 21, 2007 | Ovens
Home Logo
Top Sunbeam Home Experts
topcat7736
Level 1 Expert
Andrew Taylor
Andrew Taylor
rhodesworks
Are you a Sunbeam Home Expert? Answer questions, earn points and help others
