Question about GE Microwave Ovens
Have a GE Profile Microwave Model # PVM1790SR1SS and the control board is bad. I have the control panel out but after taking all the screws from the board it seems to be stuck where the Knob goes thro
Do I just pull on it . Don't want to break it. All the wires have been removed
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
  • 12 Answers
SOURCE: I have accidently locked the control panel on my
Press and hold clear/off button for approx 5 seconds to lock/unlock. Be Safe
Posted on Dec 19, 2010
GE Profile microwave PVM1790 starts, what I believe is an internal fan, when I open the door. I sure hope it's not the microwave component frying me.
You probably have a defective door switch, or a bad relay. You are not being microwaved. It would blow its internal fuse to prevent that from happening.
Jan 16, 2017 | GE Microwave Ovens
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
How do I replace a door on a GE Profile Microwave oven model PVM1790SR1SS?
Start by removing the screws on the inside of the door. Most of the parts also snap into place. These are saftry screws so you need a special tool.
Dec 20, 2014 | GE Microwave Ovens
Ge profile microwave f3 error and beep
F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
1 Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
2 Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
3 Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
4 Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
5 Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
6 Repeat Step 5 for the other membrane that is on the control board.
7 Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
8 Peel the wax backing off of the top membrane, then place it on the control board.
9 Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
10 Plug the microwave back into the power outlet and reset the clock.
Hope this helps.
Jul 01, 2011 | Microwave Ovens
Does GE JVM1190SY Profile have internal fuse? If so, how do you access it?
yes it does, open the door and on the inside edge of the control panel is a couple screws. take them out and you can open the panel the fuse is located behind the panel in the micro up near the top.
Apr 21, 2010 | GE JVM1190SY/WY/AY/BY Microwave Oven
Where can i buy a control panel for a ge profile microwave model hvm1540
If you have pads failing on the membrane keypad or an "F3" error, you can buy the control panel assembly with a new keypad already attached here.
(You will need to enter your full model number from the tag in or on the unit, such as HVM1540WW001, etc.)
If you have other trouble, and it is the control board ("smart board") that is at fault, you can buy a new one here or you can get it repaired here for only $39.95 in most cases.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jan 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
GE profile microwave
Most likely problem is your Smart card has fried.Its located on the removable panel that your display is attached to.If you remove the screws that open this Clock Panel (un plugged from power first) the display panel will swing down and you will see the circuit board I mention (Smart card/control board ).Look for a visible burn on this board.If you see one ,replace the board. Please Rate This !
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 02, 2007 | GE JVM3660 Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
