Question about Epson Office Equipment & Supplies
Replacing ink on an epsom wf7010 with generic ink
Ikeep getting the white realignment stripes through my image after putting in the generic cartridges from Inkfarm. The colors are great, just like Epsom inks, but I can't get the white strips to go away no matter how much I adjust the realignment feature in the utility screen ...? Please advise.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Try Genuine Epson cartridges and if the white strips disappear then you know it's the generic carts. If not then clean the printer heads, if that doesn't do it then get a new printer.
Posted on Mar 20, 2014
  • 1019 Answers
SOURCE: epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Posted on Jun 22, 2008
rey_romero
  • 9 Answers
SOURCE: Error message - no ink
Hi Maria,
Try removing all of the ink cartridges again. Open the cover and remove all of the inks. Close the cover and turn the printer off. Leave it off for about 30 to 45 secs. Turn it back on. Install again the ink cartridges. Check if it will charge after closing the cover.
If it still says that ink need replacement, check your lcd panel. Usually it will tell you what ink cartridge needs replacement. This might be a faulty ink cartridge.
Posted on Sep 09, 2008
rotorcrafts
  • 302 Answers
SOURCE: epsom stylus color 680
Try the following it may help.Please download the following software.and install it.
http://www.ssclg.com/download/sscserve.exe
Now select the appropriate printer model in the configurations tab.Now close this window and a small printer icon will appear in the taskbar.Right click on it and go to Protection counter and select "Clear counter overflow".
just do this and you printer will work fine again.
Thankyou,
Mohsin Idrees Khan.
Posted on Apr 10, 2009
  • 159 Answers
SOURCE: Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Posted on Dec 29, 2009
pineworks
  • 4041 Answers
SOURCE: Epson Printer Cartridges
Hi
Some times it needs a good clean up but this is up to you if you want to do this I put down here. But after you don this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
Testimonial: "I've not tried this yet, but I really appreciate the time you've take to write all this."
Why after installing new ink cartridges, the system says to realign scanner. never saw this before.
Realignment procedure is typical when replacing ink cartridges. It is a pretty straight-forward process and takes only a few moments. Most printers provided detailed instructions on the alignment page it prints - otherwise Google your printer for instructions. Alignment ensures that there are no gaps or white lines in text or images.
Jul 14, 2015 | Epson Artisan 810 AllInOne InkJet Printer
I keep getting lines in any pink/purple printing no matter how much aligning and nozzle cleaning I do. Have changed the Magenta cartridges several times too. I have had to give up buying Epsom ink as it is...
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am using non genuine ink cartridges in my epsom stylus printer which have been working perfectly well but now it saying my ink cartridges are not recocnised all cartridges are insrted oroperly what could...
That sounds like your problem. Maybe you were able before, but not now.
Apr 04, 2010 | Epson Stylus D92 InkJet Photo Printer
Sx405 will not recognise any cartridges . even epsom cartridges. at the moment i have 1 cartridge. black, not epsom, in the printer, but will not recognise any of the other colors
Mar 22, 2010 | Epson Office Equipment & Supplies
The colours my epsom dx7400 printer is printing out are nothing like what they should be. I have tried cleaning the heads and adjusting the colours but it has made no difference. The colour is an overall...
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 21, 2010 | Epson Stylus C86 InkJet Printer
My printer was printing fine, iloaded new ink
Epson does not like Generic/Compatible Cartridges
MUST BE GENUINE
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Put back in Genuine Cartridges, and see if it works. This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 04, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
