Question about JBL Boating
I NEED ONE CONNECTOR PIN FOR JBL MODEL MR-6.2
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need a copy of JBL
You can get the manual on the link below.
http://dl.owneriq.net/c/cb352b7d-79c1-4051-aea2-cd7757c6755a.pdf
http://www.premiumleisure.com/Manuals/nov07/Hydro_Spa_JBL_Stereo.pdf
Posted on May 15, 2011
tgvern
  • 281 Answers
SOURCE: HD 6970 - POWER SUPPLY CONNECTORS
YES, if your card has 2 power connectors, they should both be connected. Always, Always, Always!
I would rather use 2 separate cables, I am having a hard time imagining what kind of "jumper" your a talking about. That sounds kind of Hinky, so before proceeding I would strongly suggest that you make sure that your power supply meets the power needs (for Watts and Amperage) for your new video card. Check out your video card's specs in your documentation, and look for a sticker on your power supply for its specifications.
Posted on Jan 29, 2012
This question is for Bud Martin or anyone but Mr.Martin has a photobucket demo with my Model and power suppply. I have a Viewsonic N3252W with a Darfon 4H.B0350.001/D2 power supply.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Sep 29, 2016 | ViewSonic Televison & Video
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
I can't find whether or not The JBL MR-17 will
I have looked at several sites and none say that they do so I assume they don't.Also if a player does it normally says on the front.
Jun 09, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Radio locked, code needed
you have to call jbl and give them model and serial number may charge $25
Jan 04, 2009 | JBL MR-5 CD Player
Jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Boating Logo
Top JBL Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a JBL Boating Expert? Answer questions, earn points and help others
