Remove control board from PVM1790SR1SS
Have all the screws removed from board but it seems stuck where the knob goes through
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
You should remove the knob from the front use a screw driver
Posted on Feb 10, 2014
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: I need to remove the timer from my Kenmore 80 series washer.
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
I have a 3 burner Weber propane grill. The control knob to the first burner is stuck in the open position ( pressed in and won"t pop back out.) What should I do?
Okay turn off the propane 1st . take the control knob off . Spray the control with wd 40 let this soak in the replace control knob and try and turn it back to the off position this may take a few goes . once this out you will need to grease the plug on the control there should be a screw od screws which holds the plug in . You can remove this and grease it . Be careful when removing do not loose the spring inside you can remove the plug with some longnose pliers , put it back the same way it came out .
Oct 28, 2016 | Heating & Cooling
GFDN240ELOWW
My husband just fix my GE Dryer GFDN240WW "Start Button broke" issue. Here is what he did; He removed the control knob to access the phillp screw. Unscrewed screw and lift up on control to remove panel and unhook power supply. Then set control panel on face. Unscrewed 5 larger screws to removed black plastic panel w/ mother board attached. Set board aside and located power button which was broke off. Compare button to all other buttons on panel to see how they are attached to panel. My husband used Plumbers Goop from Lowes store to attached power button like the others. Then he reassembled the dryer and presto! It works!
Jun 09, 2012 | GE Dryers
POWER BUTTON STUCK IN MOGEL # GFDN240ELWW
I took off the front panel by removing the philips head screw behind the control knob. The front control panel will lift straight up. Remove the 6 philips head screws which secure the control board to the inside panel. When you lift up this module you will see the power button. It is made from cheap plastic including the hinge. Only way to repair is to either super gluie the hinge or replace the entire control panel. I think this is an extremely poor design, especially coming from G.E.
Jul 24, 2011 | GE GFDN240ELWW Dryer
I have an error code 68 what is this?
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the Electronic Control Board (Part Number AP3851146 if the error code continues to appear after the button is unstuck.
Press and hold simultaneously the Select and Cancel buttons for six seconds to reset the control then immediately after the buzzer sounds, turn the cycle selector knob 5 clicks counterclockwise to position the cycle indicator light second (Touch Up) from the bottom.
Press and hold the Options and Cancel button simultaneously for two seconds to enter the service diagnostic mode. The buzzer will sound three times and all of the LEDs will flash indicating the service diagnostic mode has been entered successfully.
Rotate the cycle selector knob 4 clicks to the Heavy Duty cycle; the motor runs with the heater off. The buttons can now be tested. Press each button and all corresponding LEDs should flash; otherwise the button is stuck or a faulty. Unstuck the key and perform the key test again; replace the control board if the problem is not resolved.
Access to the control board requires the removal of the top panel and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off the dryer.
Remove the four screws, two on each side, securing the console to the front panel then flip the console forward. Disconnect the wires from the control board and lift the console off.
Remove the five screws mounting the control board to the console and lift the control off. Remove the control board's rear cover by releasing the two locking tabs the flip the cover off the control board. Try to unstuck the faulty key and reassemble the dryer in reverse of the disassembly steps.
Hope helps.
Apr 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Stops working with code e68
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the electronic control board (part number 134557201) if the error code continues to appear after the button is unstuck.
Apr 27, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Jan 01, 2010 | Kitchen Ranges
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
