Question about Polaris Pb4 - 60 Booster Pump
The PB4-60 doesn't fit
My booster pump is hard plumbed. i purchased the pb4-60 and it doesnt fit. the impeller and plastic housing attached to the motor is too big. can I buy the old pump or do i have to replumb? i really don't want to replumb it.
  • 372 Answers
They changed the design of the pump a few years ago when Zodiac bought out Polaris. Re-plumbing isn't that hard to do, but if you are not comfortable with it a pool tech or handyman should be able to do it for about $60.
Posted on Feb 13, 2014
john224
  • 1378 Answers
SOURCE: I have a Polaris PB4-60
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: my pb4 booster pump is leaking from the booster
Replacing the pumps mechanical seal should fix the leak. The whinning may be from bearing damage due to the leak. If you are unsure how to fix it, try a local electric motor repair shop. We charge about $55 - $60 for that seal and bearings installed.
Posted on Aug 27, 2009
john224
  • 1378 Answers
SOURCE: I am having difficulty removing
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Posted on Nov 08, 2010
  • 990 Answers
SOURCE: I have new impeller &
Rubber toward the impeller,so when you screw the impeller back on the ceramic ant the graphite on the other half face each other. This is so the graphite wears smooth against the ceramic.
Posted on Nov 14, 2010
adamh294
  • 310 Answers
SOURCE: Is it a big job to replace the bearings in my pb4
It is not complicated if you are a mechanic. You do however need a good set of bearing pullers, plus the bearings. Bearing pullers are not cheap, bearings are. If you plan to do many of these in the future, or have a use for a bearing puller, then it is worth the money. Otherwise, it will be cheaper as a one time cost to have it done by someone with experience.
If you do want to do it yourself, e-mail me here for instructions.
adamh@newconceptchem.com
Posted on Jan 20, 2011
Impeller rubing on the housing after motor starts.
The motor bearing on the pump end may have failed. Looks like this pump cost about $200 so having it inspected and repaired may be close to that. Unless you know someone who works cheap or you have some mech abilities. Here is a link to an exploded assembly parts drawing.
http://mypool.com/images/parts-diagrams/Polaris-PB4-60.jpg
Nov 15, 2013 | Polaris Pb4 - 60 Booster Pump
Water Flow to Booster Pump
plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Apr 25, 2013 | Polaris Pb4 - 60 Booster Pump
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
I have new impeller & seals for pb4-60 booster pump and need to know the orientation of ceramic/rubber seal should be inserted into impeller - rubber lip toward or away from threaded brass wijidigit?
Nov 13, 2010 | Polaris Pb4 - 60 Booster Pump
I am having difficulty removing the impeller on my Polaris PB4 Booster pump. I removed the seal plate and held the motor and attempted to turn the impeller counterclockwise. Can't get the impeller to...
John
Nov 07, 2010 | Polaris Pb460 Polaris Booster Pump...
When I turn on the power, my polaris pb4 pol pump buzzes for a few seconds and then stops and doesn't do anything,
Check for a jammed impeller in the pump. Otherwise, sounds like the capacitor is probably bad. Either in a raised housing on the outside of the motor or in the back under the motor cover. The capacitors are rated in uF or micro farads. Be sure to get the right one...
Jun 16, 2010 | Polaris Pb4 - 60 Booster Pump
How do you change the shaft seal on a polaris pb4-60 pump?
BE CAREFUL YOU CAN BREAK THE SEAL PLATE BY OVER INSTALLING THE #1000 SEAL , TAKE 6 BOLTS OUT UNSCREW IMPELLER THE TAKE THE 4 BOLTS THAT HOLD THE SEAL PLATE TO THE MOTOR, KNOCK OUT OLD SEAL FROM SEAL PLATE USE SOCKET THAT FIT OVER SEAL. I USE A 1 1/4 SOCKET. THEN REPLACE CERAMIC IN IMPELLER (READ INSTRUCTIONS WITH SEAL) OR TAKE IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. HAVE HIM DO IT . $ AROUND 40.00
May 24, 2010 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
67 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
