Question about Garden
Simpson ps 3030 pressure washer manual - Garden
Why does my Simpson pressure washer mega shot V3100 continue to build pressure when I release the gun and stays on high speed
There is a thermal pressure relief valve on the pump that opens when the pump starts to heat up.
Jul 04, 2016 | Simpson Garden
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual:
http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf
No oil is required for the pump.
10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily).
The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine).
When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
Dec 27, 2015 | Simpson Garden
Leaking water
Can you tell me where it's leaking from.
see link for parts.
http://www.ppe-pressure-washer-parts.com/simpson-ps2600-pressuew-washer-parts
Mar 21, 2014 | Simpson Professional 2600 PSI Pressure...
Im not getting the simpson 3200 psi to shot out water
Give us a all when you. An be at the washer.
http://www.ppe-pressure-washer-parts.com/page/419383926-32577450
Nov 03, 2013 | Simpson PS3200 Powershot 3200 Psi Direct...
Simpson 3100 psi washer will not spray
The pressure relief valve is sticking open.
May 15, 2013 | Garden
Finding service manual Simpson Megashot MV3100
http://lawnandgarden.manualsonline.com/manuals/mfg/simpson/simpson_pressure_washer_product_list.html
May 22, 2012 | Garden
I have a Clarke King 100 hot wash with a wiring problem please can you help with the 3 connections from the pressure switch ?
the pressure switch is so the burner goes off when you stop squeezing the gun, there are only 3 different combinations wire1 and wire 2, wire 1 and wire 3, wire 2 and wire 3, it does not matter which way you connect them. You will know when it is correct as the burner will only work when the gun is squeezed and water is coming out of the lance nozzle at high pressure.
Jul 26, 2011 | Simpson King Brute 3030 Hot Pressure...
Low pressure from wand
where do i get a washer for the wand?
May 21, 2010 | Simpson PS2600 PowerShot Commercial-Duty...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
