Question about LG HBM 730 Bluetooth Headset Wireless Headset
Blue light lg 730
Is there a way to turn the flashing bleu indicator light off?
  • 54 Answers
No its built in.
You can paint the light with a black permanent marker though, if you want it back you just remove the paint.
Posted on Feb 12, 2014
I THINK MY BATTERY IS FRIED ON MY LG HBS 730
SOLVED: MY LG TONE HBS-730 WILL NOT CHARGE - Fixya
www.fixya.com/support/t17797017-lg_tone_hbs_730_will_not_charge
Apr 20, 2013 - MY LG TONE HBS-730 WILL NOT CHARGE When i plug the ... with this headsets to prevent frying the small battery, especially if they charge ...
fix/repair/extend battery of HBS-730/750/700 very easy and simple ...
? 1:44
https://www.youtube.com/watch?v=qLwpemHhLRc
Jan 30, 2017 - Uploaded by techtronicity
fix/repair/extend battery of HBS-730/750/700 very easy and simple way ... I put my headset to charge and ...Missing: fried
LG HBS-730 USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > LG Manuals > Headphone > HBS-730 View and Download LG HBS-730 user manual online. ... DOWN button for 1 second, you can check the battery status of the HBS-730 while in standby mode or playing music. ... My on & off switch on my 730 won't turn my earphones on.Missing: fried BATTERY IS FRIED ON MY LG HBS 730 Google Search
Jun 24, 2017 | LG Radio Communications
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
52" LG LCD rear projection screen blue discoloration
bonsoir!ce que vous avez ici c'est un probleme de light engine ;c'est surement un le filtre bleu qui est brule et cette tache va remplir tout l'ecran apres,il faut contacter lg et manifester parceque le light engine coute tres cher 900 us
Oct 17, 2008 | RCA HD50LPW175 50" HDTV
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Jun 29, 2008 | LG HBM 730 Bluetooth Headset Wireless...
I know NOTHING!
The LG HBM 730 has a muti-function key on the front of the bluetooth. You can recognize it my the semi-circle (phone) symbol. When Bluetooth is on it is 'red'. It is actually a button (not obvious though). Hold it in for 8 seconds or so to turn it on. The light is a give-away when it's on.
Pairing is just the term used to indicate your phone recognizes your bluetooth. You need to set up your phone to recognize the bluetooth that you have.
May 28, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
46 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
