Question about Xerox Office Equipment & Supplies
Xerox interrupt button is flashing - Xerox Office Equipment & Supplies
Interrupt button is flashing, machine won't power up on my Xerox WorkCentre 3655
First try unplugging machine from power source for 10 min. Open front (toner) door, plug in and power on.
May need to try loading software via usb. If it doesn't take, repl HDD and load s/w.
Oct 03, 2017 | Xerox Office Equipment & Supplies
Xerox Phaser 7760 shows the error 004-350, what can I do?
You can find answers to your Xerox questions at www.xerox.com/support .
Solution : Power Off the Printer, Wait 45 Seconds, Then Power On the Printer Some problems can be resolved by powering the printer OFF and ON.
WARNING: Only use the power switch on the printer to power the printer OFF and ON. Damage may occur to the printer if power is interrupted by other means.
CAUTION: When cycling power on the printer, any incomplete jobs in the queue will be lost and will have to be resent.
  1. Power OFF the printer using the power switch located on the top, right side of the Control Panel.
  2. Wait approximately 45 seconds, then power ON the printer.
Oct 23, 2013 | Xerox Phaser Office Equipment & Supplies
Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Xerox fault 37,004.40 : 134924
It tends to be the problem of heater assembly in printer .Ensure you have proper power supply to printer , if there is any interruption of power then printer won,t be having enough power to function properly and you get this error message . To solve these problem completely you need to contact service person to get it serviced .
Hope this helps.
May 03, 2010 | Xerox Phaser 8400 Laser Printer
My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Phazer 4500N
It will need servicing - you have only got half an OS loaded on it. That's why they warn you 'do not switch off or interrupt' when you are doing firmware upgrades.
Jun 29, 2009 | Xerox Phaser 4500/DX Laser Printer
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
146 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
