Question about Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25
Pump not working all the time float seems ok
Laundry tray pump. float seems ok and who sells this product
  • 3 Answers
Impeller is probably chewed up
Posted on Dec 22, 2015
Our non-submersible laundry tub pump will not shut off once the laundry tubs empty
I assume there is a float or level switch that has either gotten clogged or failed. Try cleaning the area where the switch is.
Aug 25, 2013 | Plumbing
I have a AEG OKO Favorite 675 dish washer and if you start it or open the door it sounds as if it is just draining all the time, what can be wrong?
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve.
To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit.
I gained the above knowledge by bitter experience.
Dec 27, 2012 | Washing Machines
Grtting an e4 code and pump wont start
E-4 RAC Product = Heat Sink Sensor Error, Open/Short Cct or over 95C. Commercial Product = Condensate pump float switch risen. Check drain pan is empty,
check pump is working OK. If no pump check blue jumper plug is inserted in socket CN Float.
Please write next time with model and type of unit. Thanks.
Jan 26, 2011 | Carrier Heating & Cooling
Red light flashing 4 times repeated on ceiling unit and not working
Jan 02, 2011 | LG Heating & Cooling
About once every 7-10 days, an excessive amount of water leaks from beneath our dryer, flooding our laundry room. Is there an area in the dryer that water from wet clothing is collecting before it leaks...
Their is a catch pan that has 2 float switches in it. One of them is supposed to pump the water into the water tray atop the machine.
The other is supposed to kill power if the pump motor fails. I would be willing to bet a hose came off the pump. When the tank gets full the water gets expelled to the floor. Here is a manual for condenser dryers:
ASKO DRYER SERVICE MANUAL
Jul 03, 2010 | Dryers
Upper tray does not wash clean, bottom does
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
My Fedders dehumidifier keeps reading full all the time
When you move the float up to enage the switch does it shut it off? If not you may need to adjust it
Jun 19, 2009 | Maytag M3DH30B2A Dehumidifier
Flotec Sump Pump Tethered Float - Float seems faulty. Easy fix?
it sounds like it could be a bad float switch but most of the time the water isn't high enough for the pump to turn on. it takes alot of water to turn on a tethered float. the other pumps they sell at lowes with a real float (like the one in the toilet) are adjustable and also replicable. .
Apr 11, 2009 | Flotec Simer//Omni 2957 Submersible Sump...
30 hotpoint dishwasher
#1. If you have to put downward pressure on the float in order to fill, then float switch is not OK.
#2. It would seem as though your pump impeller is missing some, or all vanes. (Not pumping water out).
#3. It will become even more difficult to find parts as time goes on.
#4. 30 years...It has done it's job. It has paid for the trip, It's time to move on, What else can I say.
Jan 27, 2008 | Dishwashers
Pump continues to run
make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Jan 01, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Utilitech 0.33-HP Thermoplastic Submersible Utility Pump PPSU25 Logo
287 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
