Question about Radio Shack Measuring Tools & Sensors
THERMOR SENSOR WIRELESS THERMOMETER
NEED MANUAL
3 Suggested Answers
breezyken
SOURCE: Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
Posted on Jan 24, 2012
  • 963 Answers
SOURCE: need instruction manual for equity wireless thermometer
Hi George,
I believe your Equity wireless thermometer is manufactured by LaCrosse Technology. Here is a link to their website:
http://www.lacrossetechnology.com/
From this page, you can search the type of wireless thermometer or weather station you're trying to use. (You didn't specify a model number in your request).
Also notice that there is link on that page for Support; clicking that will take you to the Manuals link. You will need to find your proper model number in the drop-down menu.
Also, there is a Contact link, so you can contact them directly for further assistance if you are unable to find your model's information.
Good luck, George! Hope this helps!
Posted on Feb 11, 2012
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
How do I set the time and date on my Thermor thermometer
Hold down the mode button for a few seconds > display starts to flash year > use +/- buttons to set year > press mode to present the month/day/time etc, again using +/- buttons
Nov 24, 2014 | Thermor Indoor/Outdoor Wireless Thermo
Where can i download the manual for a thermor water heater"?"
www.reliancewaterheaters.com/lit/spec/2006ServiceHandbook.pdf
May 07, 2014 | Reliance Water Heaters
Norcold 1200
replace temp sensor if same control board
Feb 15, 2014 | Dometic Refrigerators
Need instruction manual for equity wireless thermometer
Hi George,
Feb 11, 2012 | La Crosse Wireless Thermometer
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Measuring Tools & Sensors Logo
32 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Susan Jamieson
Level 1 Expert
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
