Question about Crosley Washing Machines
Code E90 crosley front load washer CFW4500KW0
Have tried a few things but nothing working it will not let me do anything as soon as I try to start it the code comes up need to unplug it do know what to do.
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Feb 18, 2008
SOURCE: LG TROMM front load washer - the drum won't spin,
My Tromm washer has LE Error code I have restarted unplugged and restarted same error code keeps coming up.  What does this mean?
Posted on Feb 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE Adora Front Loading washer won't turn on
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Posted on Sep 28, 2010
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Washing machine just stopped wont do anything
    have u tried unplugging it a few minutes then restarting it? some units also have a shut down fuse and it may have shorted? U are getting power? other wise a bad terminal block
    Jul 07, 2014 | Crosley CW6000 Front Load Washer
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    Need a service manual for
    Hello Colleen, I am happy to assist you!
    I see that you are interested in locating a service manual for your Crosley washer, CFW4500KW0. This type of data is very rare to find, however I successfully found the Owner's Guide, Installation Instructions and Parts Manual. Hopefully you find all the information that you are looking for. Best regards!
    Frigidaire Manual Search Results
    Jan 24, 2014 | Crosley Washing Machines
    E90 error
    If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
    Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
    Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
    Code nf shows on my washer
    unplug for 15 mins and plug again to rest
    Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Crosley CFW8000GR OE Problem
    Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
    Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
    Crosley digital front load washer
    jus try to lubricate the lock n then try.... it wil work
    Jun 17, 2008 | Crosley CW5000 Front Load Washer
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    71 people viewed this question
    Top Crosley Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Gerry Harvey
    Gerry Harvey
    Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
