Question about Toshiba Satellite A135-S2276 Notebook
Does not turn on
My satellite froze up so i shut off the computer but now it does not want to turn on, the power light is working but the hard drive light is not on. whats wrong??
  • Lindzee Nov 06, 2007
    My Toshiba Satellite A135 starts to power up but a few seconds later I can hear the hard drive stop and nothing else happens. The hard drive indicator light blinks once or twice then nothing. The yellow light on my CDRom stays lit solid yellow. It worked just fine but the next time I turned it on the problem started. Thanks in advance for any help.
Same problem with my 135,i've been told it's a motherboard problem and Toshiba was aware of it and wont do anything abt it
Posted on Nov 21, 2009
  • 1,006 Answers
U have to try to format it..
Reason is u are infected and if u format it the virus will not remove it will be in SYSTEM BACK UP MEMORY and when u format automaticlly on WELCOMEN SCREEN u are infected..The best for u is if u put ur hdd in another laptop as external and format it with CMD.When u are done put it back to ur pc and format it with original winxp!!!
If u still have a problem just contact me!!!
Posted on Oct 26, 2007
I was running my Toshiba Satellite A135-S2376 when the screen completely froze. The cursor wouldn't move, and I could not restart the computer with control-alt-delete. I held the power button until it...
I've heard a lot about freezing problems on toshiba as well as others like this. Most common issues are one of two things. One is a damaged RAM module. The second is one of the video card chip sets have fried or are slightly overheating causing the laptop to shut down. Most common with Nvidea and ATI Radeon series graphics cards.
Jan 05, 2011 | Compaq Presario Notebook
My Toshiba A215-S4697 froze and I shut it off by holding the power button down. When I went to turn it back on the power light came on but the Satelitte light didn't. The screen wasn't on either and the...
it could have failed,but its more likely you have sequential procedures for the power button,like holding it down for more than 5 seconds etc--you might have just put your machine into "standby mode"--check manufacturers site for power key process--good luck!
Davey snake!
Oct 17, 2010 | Toshiba Satellite A215-S4697 Notebook PC
Hi, I re-installed the hard drive on this laptop (Toshiba Satellite M45-S169), but the hard drive is unresponsive. Not sure if I installed correctly, or the hard drive is dead. The power light comes on,...
If drive not spinning, definitely dead. If spins and not recognized by laptop cmos, the logic board on drive is toast.
Afraid that you have a nice cute paperweight.
Sep 03, 2017 | Toshiba Satellite M45-S169 Notebook
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite A135-S2376, black screen problem
have u tried to power up with external monitor? reply back.
Oct 26, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Does it stay on with no RAM and/or CPU
Laptop will def not power up without ram or cpu.
Can you test the hard drive in another pc?
Jan 05, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
