Question about General Electric GE WPDH8900J Front Load All-in-One Washer / Dryer
GE Dryer Model # DBVH520EJ2WW Start/ Pause Button blinking and won't start... Door is closed...
4 Suggested Answers
scottowa
  • 87 Answers
SOURCE: push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Posted on Mar 04, 2009
SOURCE: wssh300g0ww will not start. start button has a
Disclaimer, I'm not a repairman! But I did fix the same problem after reading some info online and messing around. Open the lower panel-2 screws at the very bottom next to the legs, pill down, it's off- and there will be a yellow envelope on the left hand side. It will have the tech sheets in it and will tell you how to put it in a test mode. It will also tell you the codes and how to read them. If the results of the tests (my code was EB3) tell you "replace the control board" don't spend $225 on a new board yet! I was 1 step away from ordering it from sears.com when I thought I have nothing to lose at this point. So I pulled the control board out: 1.open the top -2 screws at the back pull out, lift up and its off 2. Take the upper panel off (where the lights and buttons are)-4 screws, 2 on top, 2 where the detergent tray goes in. Do take the tray out first. 3. Inside that panel you'll see the control board housing-5 screws, 2 on the left, 1 on the right, 2 in the middle, there are some plastic latches also, just use a small flathead to prop them. Unplug all the cables- I marked them so I would know where each one would go once I'm done- 4. Open the housing, again prop the plastic latches. 5. Once u have the green board in your hand wipe VERY GENTLY the back side (side that doesn't have all the components sticking out, the flat side) with a dry paper towel. On mine I could see white residue. I think it was oxidation. Since the control board housing is not sealed I think with time the humidity and vapors caused oxidation and start shorting the circuit. 6. Before putting everything back together I connected all the cables to the control board and did a test run, I was very happy when I heard the water start to fill up. Saved me $225 plus labor which probably would have cost me over $300 easily. The machine new was $550! w
Posted on Feb 25, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a front load
How to clean the filter
Technician's Service manual
I believe your pump filter is clogged. Use the links above to help you save some money.
Posted on Jun 03, 2011
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Control panel turns on but dryer won't start. Start/pause button flashing as usual, but just beeps twice when pushed.
That generally means the door is open. Assuming you have the door closed I would investigate the switch that tells the dryer the door is open. It may be bad.
Jul 10, 2014 | GE Profile DPVH880EJMG Electric Dryer
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
Gas dryer won't start
see the causes:
Power from the house
c.breakeer or blown fuse reset and replace
Door switch
test for open or defective, this close the relais for start the m.motor
Timer
dirty contact, loose wires, broken or burn, or defective timer repair and replace
Thermal fuse
test for open and replace see how
Jun 18, 2012 | Dryers
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Start button does not start dryer. All the other buttons light up except for the start/pause button and the stop button. Door is closed when the start button is depressed. No light or other activity is...
Check to see if the door is latched. If so, look at the latch and see if it is making proper contact. There is a microswitch that prevents the unit from starting if the door is not fastened closed.
Jim Hart
Jun 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
General Electric GE WPDH8900J Front Load All-in-One Washer / Dryer Logo
65 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
