Question about Casio Music
Keyboard keys not responding
Key nonresponding
I have three keys getting malfunctioned /cords not changing in left side, on split board.can this be fixed?
If those keys work normally, it's hard to see how the key switches themselves can be bad.
Is your keyboard MIDI capable? If you play the same chords, does the MIDI output look OK?
Could it be that your keyboard simply can't play all of the different sounds at the same time? I know some are limited in how many simultaneous tones can be played.
Jun 09, 2015 | Music
I just got a used Yamaha Electone FE-30, and not all of the keys are working and some of the buttons are not responding, how can i make it work, should i clean it from the inside (Key Contacts?) becau
The contacts can be dirty but most likely they are broken. Contact switches and key contacts are cheap but the labor to replace them is extensive. I would suggest bringing it to a service center if you have not taken apart a keyboard before.
Dec 10, 2014 | Yamaha Music
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
Keys not responding on my keyboard.
It needs to be plugged in to a computer with a DAW to produce sound. The DAW converts the information sent by the controller about which key is pressed and how hard and converts it into sound with a virtual instrument
Jan 19, 2011 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Keyboard not working
from what you say the humming is caused by large capasister which maybe leaking so could well be a power supply falt
or mabe dry wire
o/c on audio maybe
you need engineer freind
Aug 31, 2009 | Yamaha Full-Size Keyboard
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 | Music
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Apr 20, 2009 | Yamaha Music
Music Logo
11 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
