Question about Mr. Heater Natural Gas Garage Heater - 45,000 BTU
My Mr. Heater has been working fine for 4 years. But now there is no spark. It Seem to do everything correct except fire the igniter. I cleaned it up with a small wire brush. Now it sparks, but not at the end of the electrodes about a inch in from the tips. IS this NORMAL? And it only sparks after I have used a BBQ lighter to fire it up. The GAP is tapered IS THIS NORMAL. I am going to replace the ignitor And I am looking for a parts supplier now. But mean while back on the ranch,Baby it cold outside. Any ideas?
5 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: I'm looking for mr.heater model#mh9b parts parts
go to http://www.pinnacleint.com/
Posted on Mar 17, 2009
co7196
  • 3433 Answers
SOURCE: Can't get an outdoor propane heater to light.
turn off propan and heater. Undo the connector hose. then rehook hosewith heater valve off, Turn on propane valve real slow. Propane bottle valves have a safety that senses rapid escape, like in a wide open dump. This should reset it.Then light the pilot . should work.
Posted on Jun 10, 2009
  • 2461 Answers
SOURCE: i have a 75,000 btu mr heater and the spark
Hi clean the flame senser blow the dust out of the heater check the fan switch might be dusty jump out pressure switch see if that helps
Posted on Feb 02, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Mr. Heater Big Maxx 75,000 BTU Heater will not
Is the circuit board giving you a blinking error code?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Feb 26, 2010
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
Feb 18, 2014 | Mr. Heater Natural Gas Garage Heater -...
I am having trouible starting. Idle for several years
Service agent or change the flame failure device. make sure gas is turned on, clean out pilot jet..
Nov 02, 2011 | Mr. Heater MH12CS with Electronic Spark...
Wont fire after following start instructions
OK-- Let's go thru your trouble shooting steps, and what you found:
1.) Fuel: Sufficient, and right type?
2.) Has the unit fired and run before?-- What is different in sounds, or settings now?
3.) How does this unit ignite the fuel?-- With Spark, or with Glowing ignitor?
If Spark-- can you hear it sparking?
If Glowing ignitor, -- can you see the glowing? (in a darkened room..)
4.) Can you see that Kerosene is spraying at the nozzle?-- is the pattern correct?
5.) Have you check fuel and air pressure settings-- according to the manual?
After observing these details-- let us know what other clues you are observing now.
I'll be here to take you to the next step, if you like--- Just add your new comments in the 'respond' box-- they will send them to me for further follow-up.
Mack B
Jan 17, 2011 | Mr. Heater Portable Kerosene Heater -...
I have a 75,000 btu mr heater and the spark ignition doesnt work . do i have a bad circuit board?
Feb 02, 2010 | Mr. Heater Natural Gas Garage Heater -...
Heter trys to ignite,replaced igniter,cleaned fuel filter
1. Check the ignition transformer. It may be grounded,
or it could be defective, and need to be replaced.
2. You have already replace the igniter and the
photoeye.
3. Once the ignition transformer works, everything will
be alright.
May this tip help you.
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Jun 08, 2009 | Mr. Heater Propane Outdoor Heater/Cooker
Reddy kerosine space heater
bucklehead...I assume you discarded the 2 year old fuel... if not do so. Your fuel delivery problem could be caused by a number of things. 1. Incorrect air pump pressure, 2. worn or restricted nozzle, 3. deteriorated fuel line or air line, which in turn is creating the ignition problem, 4. the spark plug is bad OR you may not have a fuel delivery problem at all - just a photocell that has gone bad or has a wasp nest built betweem the eye and the flame (check this first). If the photocell can't see the flame it will shut the heater down. That's it's only job.
More troubleshooting tips
Apr 11, 2008 | Scheu (K50-FA) Heater
Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Feb 03, 2008 | Heating & Cooling
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
65 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
