Question about HP Officejet 4622 Multifunction Inkjet Printer
Hp4622officejet power light off when i turn it on it starts it turns off after about 15 seconds pluged directly to wall outlet
3 Suggested Answers
tumi001
  • 102 Answers
SOURCE: No Power to HP All-In-One 7310xi
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab102
Posted on Jul 17, 2009
  • 34 Answers
SOURCE: Lights blink o
Found this on the HP support site:
  • The error message Turn Power Off then On displays on the product control panel. The message might be accompanied by low power.
HP support
GOOD LUCK!!
Posted on Oct 18, 2009
Testimonial: "Yes this is a new one. The lights turn on and off even with out hookikg it to the computer. I'am useing window xp.Thank for your help."
My flat screen tv wont turn on but the lite at the bottom just keeps blinking red what does that mean its a sony tv
Unplug the tv from all devices and unplug from the wall power source. After about 15 minutes, plug ONLY the power cord back in and see if it turns on. If not, than you will need to do a factory reset. With the tv pluged into ONLY the wall outlet ( no cable, DVD or internet connection) Hold the UP arrow on the remote than press and release the POWER button on the tv. This will reset everything and the blinking red light should stop. At this point you should be able to turn the TV on and off.
IF for some reason this does not fix your issue, visit HTTP://esupport.sony.com
Good luck.
Welcome to Product Support Get the help you need
Dec 25, 2014 | Televison & Video
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Reset factory settings
Hi Harold,
Here is how to reset the HP Photosmart 8250:
Performing a full reset
1. Press the Power button ( ) to turn on the product.
2. With the product turned on, disconnect the power cord from back of the product.
3. Disconnect the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Connect the power cord into wall outlet.
6. Connect the power cord to the back of the product.
If the product does not turn on by itself, press Power button ( ) to turn it on.
Try to print.
Regards,
Sean
May 28, 2013 | HP - HP Photosmart 8250 printer
Oxc19a0003
  1. Press the Power button to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button to turn it on....
if the issue does not get resolved then service the printer..
Aug 27, 2012 | HEWLETT-PACKARD B210a AllInOne InkJet...
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
My printers ink clogs and wont print
Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
Jul 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Remotes will not sync with console
Hi there, this information comes straight from Nintendo's website. Anything I'd be typing would basically be repeating what comes from Nintendo directly:
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
May 03, 2011 | Nintendo Wii Console
My tv turn on for a second and after turn off. it is hitachi 52" old brand.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-27V10 27" TV
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
Starting up
1. Plug the printer directly to the wall outlet.
note : do not use any power surge. just plug the unit directly to the wall outlet
2. Reset the printer by unplugging the power cord at the back of the printer while its still on. Plug the power cord after 30 seconds
Aug 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Officejet 4622 Multifunction Inkjet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
