Question about GE Advantium 120 Convection/Microwave Oven
Error message use glass tray
When you hit start the error message appears, USE GLASS TRAY. Microwave will not work.
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Posted on Mar 06, 2009
jsrock516
  • 5911 Answers
SOURCE: When the glass tray turns it makes a noise. When
This problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to (and is located under) the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray that you were referring to. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 29, 2010
  • 6771 Answers
SOURCE: I have been given a microwave - it does not have a
Yes! but the microwave oven will not heat evenly you will have hot and cold spots in the food, other than that okay to use.
Posted on Jan 14, 2011
  • 6771 Answers
SOURCE: can I use the glass tray in my GE Profile convection/microwave oven when using the convection mode?
I would not recommend it, removal will insure long life.
Posted on Apr 19, 2012
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
What would cause the glass tray in the microwave to shatter
  • The glass tray had a hairline crack or stress fracture that was not visible
  • It got a little too hot in one area
  • The expansion from the heat caused the fracture to expand and therefore crack and break
An accidental bumping of the microwave plate on the countertop while going from the microwave to the dishwasher might set up the above situation. The spoon your seven year old left in the mac and cheese might have arced and nicked a small piece of the glass. Whatever the cause, microwave trays break and they break for a lot of reasons.
All foods cooked in the microwave produce heat. Microwaves themselves are not hot, but the foods cooked in a microwave get hot - some much hotter than others.
Even though most microwave glass trays are tempered, they are not designed to hold up under high temperatures. You will see most microwave trays stamped with the words "For microwave oven use only" This is to let us know that it's probably not a good idea to use the trays in a conventional oven.
Any air pockets, cracks or gaps in the glass can enlarge under heat. Since glass isn't very receptive to being stretched, breakage can occur.
for more you can read on this link
http://www.ebay.com/gds/Why-did-the-glass-tray-in-my-microwave-break-/10000000003014864/g.html
Aug 27, 2013 | Goldstar Microwave Ovens
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Our Kenmore model 721.80833500 tray jumps off its track. This has progressively gotten worse over time and now the little end wheel on the rotating arm has broken off. The microwave still works and still...
Found 2 possible solutions on the net. (1) Check the engineering change at a Sears store. They reengineered the glass tray and the narrow plastic band the tray glides on. Get the new items from Sears. (2) Cut 1/4" out of the narrow plastic band the glass tray glides on. Possible solutions that look promising.
Dec 03, 2009 | Kenmore 80809 Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
66 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
