Question about Canon PIXMA MP780 All-In-One InkJet Printer
Photo colors are all green and yellow
Have replaced with all new cartridges, cleaned, etc.  Before replacing cartridges, all photos had correct colors but had vertical black lines; now lines gone but looks like only using yellow and green colors, and they are pale and dull.  What do you suggest?
  • 3 more comments
  • Anonymous Nov 02, 2007
    I have the same problem. Is ther a way to reset the colors?? Or have the printer do a color check of some kind?? THANKS!
  • Anonymous Nov 30, 2007
    all color cartridges are new and the red one don't write!
  • Anonymous Dec 14, 2007
    This same problem, of greenish copies, began after I replaced the pink cartridge. I've cleaned the head and done all the other "troubleshooting" steps but to no avail.
  • cbstol Dec 16, 2007
    only blue prints
  • wefishak Dec 17, 2008
    I have cleaned and refreshed head, but still get yellow and green only
  • 1,601 Answers
Go to
Type in:
Certain colors are missing or no ink prints on the paper.
Follow steps to fix your problem
Posted on Nov 12, 2007
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
Printing colored lines
Vertical black lines:Check with another cartridge..Check Teflon sleeve.Vertical white lines:Replace cartridge.. replace transfer roller..Clean laser scanner unit( technical skills required) Horizontal Black lines:Replace cartridge..
Jan 31, 2012 | HP LaserJet 5000n Printer
My Epson stylus Photo R220 has 4 new color cartridges that does not print in color prints. Have tried cleaning head etc. What else can I do?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 17, 2010 | Epson Stylus Photo R220 InkJet Printer
I can't produce green colors. I have cleaned the printer head with no impovement. Can this part be replaced? How would I know if the problem is electrical and not physical? Peter
I assume by cleaning you mean pressure FLUSHING the ink channel with cleaner, not just wiping the head. You have to charge the ink channel after flushing to prime it.
The cost of a replacement part probably makes it un-economical to do a replacement.
Testing for electrical problem without schematics would be hard.
Do check that the flex carriage cable connection is good.
Nov 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced Yellow cartridge. Photos came out
Clean all cartridges to make sure ink is flowing. To do this put windoww cleaner ino a container about ten mm deep. Put the cartridges with the end where the ink comes out facing down into the container and soak for about ten minutes. After this dry off for with a paper towell and make sur each cartridge leaks color into the towell. may take a little shaking.
Sep 03, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
260 people viewed this question
old marine
old marine
