Question about Ricoh Aficio Office Equipment & Supplies
Error sc514 ricoh 1045 - Aficio Ricoh Office Equipment & Supplies
  • 82 Answers
SOURCE: how do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
M2Tech1
  • 313 Answers
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
  • 1297 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
Ricoh 1045 firmware
what exactly do you need. You will need special service card also. You better call technical support
Sep 03, 2014 | Ricoh Aficio Office Equipment & Supplies
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Ricoh 1045 error code sc 672, 961
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
What does troubleshooting code 326 of ricoh copier 1045 means?
2nd laser synchronization error. F gate 1 error. This is an optics issue. Try unplugging the machine and plugging it back it to see if the error goes away.
Nov 13, 2008 | Ricoh Aficio 1035 Copier
Nov 05, 2008 | Ricoh Aficio 1035 Copier
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
