Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
Fridge too warm, freezer too cold for GE monogram ziss420drds
Replaced icing kit 2 weeks ago. issue returned
4 Suggested Answers
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
SOURCE: Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Posted on Jun 22, 2009
Hi! I purchased the Touch Cover keyboard about three weeks ago but noticed it sometimes has issues with gauging what I am typing, especially when I'm working on a word doc and typing quickly.
This is a known issue with Touch Cover, go with Type Cover. It costs ten bucks more but is well worth it.
Ask Microsoft if you can return and replace.
Dec 12, 2013 | Microsoft Surface 2 with 32GB
Noisy gear on whirlpool ice maker when the plastic wheel turns against the teeth
The new icemaker is new and should not be doing that - return for exchange.
Nov 24, 2013 | Whirlpool Refrigerators
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
Magic Chef refrigerator model CTF1923. erratic ice production
As long as your freezer temperature is at 0 you should have steady ice production. If you have to jumper the ice maker to get it to harvest then you most likely have a bad thermostat. That coupled with the leak issue really warrants just replacing the entire ice maker.
Be sure to ask for pricing on both the ice maker by itself as well as the complete kit. You may be surprised to find that the entire kit (including a new valve, line and bucket) will cost lest than just the ice maker by itself.
Jun 13, 2010 | Refrigerators
Batteries will not charge
Ni-cad will go bad if they sit for a long time
before charged, now Ni-mi you can charge it
at any time,so next ask or look for NI-MI
they will know what you are talking about.
Hope this helps.
Sep 09, 2009 | Porter Cable-Cable PCL180DK-2 18-Volt...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice Flap on my LG LSC26905TT will not close after ice dispences
There is a kit that will replace the parts you need.(fountain Kit)
Jun 14, 2008 | Refrigerators
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
