Question about Cuisinart Coffee Makers & Espresso Machines
Sir, my cuisinart coffee grinder DBM-8 is not working
My coffee grinder stopped working suddenly
4 Suggested Answers
SOURCE: Cuisinart DBM-8 coffee grinder
Have you tried checking the output chute at the bottom to see if it is clogged up? I was having low flow issues, which is how I found this post, and went and cleaned it out completely. I was amazed, and a bit disgusted, at how much powder was stuck in there. The top screws off nice and easy. then just use the brush down the chute there and at the front behind where the bin is. I also ran popping corn through it and got out even more. Then I threw all the attachments into the dishwasher, top rack like the manual says.
Hope that helps you.
Posted on Dec 31, 2007
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
SOURCE: coffee grinder not working
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Posted on Feb 07, 2010
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart DBM-8 coffee grinder started by itself.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Nov 02, 2012 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder does not run at all.
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Apr 04, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder will not start
Make sure that the coffee ground container is fully inserted. You may need to make sure there are no grounds are keeping it from seating properly. Use something soft such as a toothpick to clean it thoroughly...Good Luck.
Mar 05, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Jan 28, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart grinder stem wobbles
Search Cuisinart's website for DBM-8 - that model has exactly the same parts as your Cuisinart. If you call them, they may even cover it under warranty.
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart grinder wobbles
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Dead machine
It's under warranty, contact Cuisinart for repair.
Jun 21, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
