Question about HP PSC 2110 Color Printer
Does this mean i need a new printer? - HP PSC 2110 Color Printer
My printer is reading error E5... what does this mean?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 15, 2011 | Canon PIXMA MP210 InkJet Printer
My 2840 is saying install drum , does that mean I need a new drum or some other problem?
Well if it says need install drum, you might need buy new one. if still not solve the problem then maybe bad sensor inside the printer
Feb 11, 2011 | HP LaserJet 2840 Printer
I have a hl 7050 printer. Recently on the screen mention "Error E52". What does it mean?
That error means the fuser has gone out, could be a dead lamp, or temperature sensors. Chances are you need a new fuser if you have 50,000 or more prints on this machine. www.precisionroller.com will have a new fuser.
Jan 28, 2010 | Brother HL 7050 Laser Printer
Troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
What does error 6500 mean?
6500 mean hardware error.In most case error in logic board assembly.Sounds like you need a new printer.
Nov 03, 2009 | Canon Pixma MP450 All-In-One InkJet...
Brand new printer and quality of print is poor - lines running through the colour picture
If this is a laser printer this means the drum is scratched and it is creating a line in printouts.
If it is an ink jet printer this usually means you need to run the cleaning utility or do a cartridge alignment utility
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have the canon mx310. cannot print out what is in the memory. it reads new B-CRT AND C-CRT
the message - recommend new: C-CRT means it needs a new colour toner cartridge and recommend new: B-CRT means it needs a new Black Cartridge.
Oct 01, 2008 | Office Equipment & Supplies
Red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Sep 16, 2008 | Sharp AL 1631 Copier
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
Problem with my printer
well first here http://emeasupport.epson-europe.com/downloads.aspx?LNG=EN-EU&Search=1&data=1bANIZf8BRVoS83cS1PVis/kIVxbLcWZ9JD5vhjblgJTVeIjQGvfyu2+tOhzwN03 for more info & your drivers but what you need is new ink cartages
May 25, 2006 | Epson Stylus C46 InkJet Printer
HP PSC 2110 Color Printer Logo
11 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
