Question about Toshiba TDP-T91A DLP Projector
Do this projector has a filter that can be changed
Message stating the filter needs to be cleaned
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Clean the filter
2,reset the filter timer: menu-setting-used hours of filter-reset the timer
Posted on Feb 11, 2014
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
How do I change the filter on my CP S335 projector. It is saying no air flow.
WARNING ?Before caring, make sure the power switch is off and the
power cable is not plugged in, then allow the projector to cool sufficiently. The
care in a high temperature state of the projector could cause a burn and/or
malfunction to the projector.
?Use only the air filter of the specified type. Do not use the projector with the
air filter and filter cover removed.
?Avoid wetting the projector or inserting liquids in the projector. It could result
in a fire, an electric shock, and and/or malfunction to the projector.
CAUTION ?Please replace the air filter when it is damaged or too soiled,
and also when you replace the lamp.When the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the air filter becomes clogged by dust or the like, internal temperatures rise and the power may be automatically turned off for malfunction prevention.
1. Turn the projector off, and unplug the power cord. Allow the projector to cool for at least 45 minutes and prepare a vacuum cleaner.
2. After making sure that the projector is cool adequately, slowly turn the projector so that the lens-side is facing up. Please be careful for a projector not to fall. While the projector is placed lens-side up, hold the projector.
3. Putting a finger on the filter cover's knob, slide the filter cover in the direction of the arrow to remove it.
4. Holding the air filter's knob, pull the air filter off.
5. Apply a vacuum cleaner to the vent of the projector for the air filter. And then slowly turn the projector bottom up.
6. Apply a vacuum cleaner to the air filter and filter cover.
Please replace the air filter when it is damaged or too soiled.
To prepare a new air filter, contact your dealer and tell the air filter type number = NJ09702.
An air filter of specified type will come even with the replacement lamp for this projector.
7. Position the cleaned air filter or a new air filter into place, and push the points
of "PUSH" word with claws to fix the air filter.
8. Replace the filter cover and snap it back into place.
9. Slowly turn the projector so that the top is facing up.
10. Turn the projector on, and reset the filter time using the FILTER TIME
function of OPTION menu (?37).
NOTE • Incorrectly resetting of the filter timer (resetting without replacement,
or neglect of resetting after replacement) will result in incorrect message
functions.
Jan 03, 2011 | Hitachi CP-S335 Multimedia Projector
I cleaned the filter, but keep getting "Clean the Filter" Message. Is there something else I need to do?
Hello :
In some projectors after cleaning the filter you need to reset the projector .
Please check this video .
Please don't forget to rate !
Apr 12, 2010 | NEC VT670 Multimedia Projector
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
How we can clean airfilter because message is appearing regarding clean your air filter
check in the menu to see if there is a filter timer that you can reset. if so, reset it. if not, there is an air flow sensor on the projector that will send that message if the air flow is decreased so the projector does not overheat. find the filter and remove it. blow it out with canned air and blow out the projector as well. replace the filter and enjoy!
Nov 05, 2009 | 3M X50 Multimedia Projector
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
Vt575 pROJECTOR
My VT440 says this when it gets to it's pre-defined service life. (a certain amount of hours)
As long as you pop the filters out regularly and clean them (I use a vacuum cleaner) you shouldn't need to replace them.
After that, go into the projector options (with the remote control) and reset the factory defaults... otherwise it has no idea that you have actually changed the darn thing and keeps complaining no matter what! =-]
Aug 20, 2008 | NEC VT460 Multimedia Projector
Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Aug 19, 2008 | Office Equipment & Supplies
Cleaning the filter
Clean or replace the filter - check manual or Tech support for this machine.
May 17, 2007 | Hitachi XGA Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Toshiba TDP-T91A DLP Projector Logo
113 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
