How to play a usb flash drive - Televison & Video
Have a pioneer truck stereo. When I plug in my memory stick into my USB it plays a couple of songs then I get a error 19.
USB Flash Drive - Issues With Music In Car - Need to format to add ...
www.neowin.net > ... > Hardware Hangout
NeowinAug 11, 2014 - My Radio can see the USB drive and plays the music directly from it. ...drive, after that plug it in your car stereo, play a few songs randomly, disconnect, ....The index file should stick out like a sore thumb amongst your mp3 files. .... I haveripped some CDs into my computer, and then synched them to a flash ...
How to Format a USB Thumb Drive for Your Car: A Solution ...
doughaslam.com/.../formatting-a-thumb-drive-for-your-car-a-solution-to...
Nov 4, 2010 - Not being an iPod owner, I use it to connect a thumb drive that is big enough to ... There were a few obstacles to getting this just right, however, and I thought I ... I renamed the files (once copied to the USB stick, never touching my ... I could cram more info into the short car stereo display (the example in the ...
#234 - My USB flash drive shows as unsupported in my ...
? 1:19
https://www.youtube.com/watch?v=MgaZwtmbuA0
May 29, 2013 - Uploaded by hondadailytv
My USB flash drive shows as unsupported in my Honda vehicle. ... WMA or AAC when a USB flash memory device is playing. The USB .... Format USB via FAT32 file system and then Uploadsongs in mp3 format and plug into your car and .... I would haveto move/delete all my songs from the USB stick and ...
Jan 21, 2016 | Pioneer Car Audio & Video
How can we play video from a USB device? Why can we not download more apps???
Shop for tv How can we play vide... on Google
WD TVĀ® Media Player
$109.99
Staples
(165) Hauppauge Computer Ha...
$84.99
Dell
(400) C2G 29351 Micro USB to...
$21.23
Sears Audio?Technica ATR2USB 3.5...
$13.95
zZounds Diamond ATI TV Wonder H...
$39.92
B&H Photo-Vi...
(12) Search Results
    USB Flash Drive Movies on your Flat Screen TV - YouTube
    ? 4:10
    https://www.youtube.com/watch?v=ge4Wo9FQf8w
    Oct 5, 2014 - Uploaded by 21NorthMedia
    How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
    Watch a movie on your TV from a USB drive. - YouTube
    ? 2:40
    https://www.youtube.com/watch?v=jOhvbdVkPaM
    Nov 10, 2012 - Uploaded by DIYallday
    I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
Jan 05, 2016 | Televison & Video
From USB port unable to play the movies. The message unable to Protect, while opening movies from USB/ external Hard disk to play on TV Hisenese ER31607A
May be Speed of USB flash drive is equal or below Class 4.0. Try to check with Other higher speed USB Flash Drives. (Class 6 or Class 10 or HDMI)
Mar 21, 2015 | Hard Computers & Internet
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
Jun 08, 2014 | Pioneer DEH X3500UI - radio / CD / MP3...
Don't work when it is cold
what is ur flash drive model no, and of which company it is?
Feb 20, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
Bought 4gb sandisk cruzer flash drive stored music from computer but it won't play the music on the car fm transmitter
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it.
Unless your transmitter states that it plays different media formats that is but i have never heard of that before.
hope this helps.
Dec 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
WHEN YOU PLUG IN THE FLASH DRIVE TO A COMPUTER USB PORT WHAT DO YOU DO IN ORDER TO PLAY MUSIC??? i know a box comes up which says what do you want to do, view files & etc but do not know how to play...
If the autoplay menu doesn't show up, just go to My Computer and double click whichever drive the USB is in. If it does, just view the files, then find and double click the music files you have in the flash drive. It should open whatever music player you have on your computer and play the music.
Hope this helps.
Jul 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Is it possible to watch videos from a USB?
usb is an input on on a computer and what u stick in that is a flash drive now a flash drive just holds data its like a memory card. when u stick that in the computer it reads what ever is on that flash drive movies are not played on a usb they are played on the computer which would be by windows media player. thats what always the movie to play. usb is only to transfer data and safe data from one place to another.
May 18, 2011 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
