Question about Calphalon Quick Brew 12-Cup Coffee Maker
Won't start brewing
The LED panel seems to work. The brew notification comes on but water doesn't move from the resivoir.
The "descale" notification continues to come on,
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
Jul 31, 2011 | Keurig Platinum B70 Coffee Maker
Will not brew
mcdevito75 here, Your coffee maker may need cleaning, specially if the brewing is very slow or a lot of steaming is happening when trying to brew. Or your machine is faulty. If the water doesn:t move from the resovoir to the brewing spot the machine is faulty and will have to be replaced.
Jul 10, 2010 | Cuisinart DCC-2000
MY b60 all of a sudden won't fill a full cup when it brews. I descaled it and it works just fine and fills the cup with water and no kcup in place. When I brew with the kcup it only half fills.what can I...
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Dec 30, 2009 | Keurig B60 Coffee Maker
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Calphalon Quick Brew 12-Cup Coffee Maker Logo
44 people viewed this question
Top Calphalon Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Calphalon Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
